Sponsored by: CARiD
OME springs with bilstein HD shocks?
Old Jul 11, 2011 | 09:27 AM
Greg_Canada's Avatar
Hey guys (and girls).
I've got bilstein HD shocks with low K on them (dont really need to upgrade).
I'm looking at getting OME springs and shackles to replace the worn out springs on my truck....
Does anyone know the extended/ compressed length of the stock lenght Bilsteins or OEM shocks?
OME are 9.8" / 15.3" front (5.5" travel)
and 14.1 / 23.1" rear (9" travel)
Wondering if i can get away with just buying the new springs and keeping the billy's...
Thanks....
Old Jul 12, 2011 | 06:46 AM
xxxtreme22r's Avatar
you can get away with using stock length shocks I did it with 2" springs/longer shackle and torsion crank up front with my procomp es3000's. however your gonna sacrifice a bunch of down travel. At least 2" worth maybe even more depending on what your setup is. (coil spacers, longer coils (ala LC) etc etc).
You best bet is to put the springs on and measure for yourself what your gonna need.
This topic has been covered so many times in the past, it's newbie territory and surprised this thread wasn't deleted yet.
Old Jul 12, 2011 | 08:09 AM
blake.nemitz's Avatar
could always go the cheapo route and get those extenders that go on your shocks. i wouldnt but in a pinch for a while it might work
Old Jul 12, 2011 | 08:19 AM
It has been deleted.
And i couldn't find anything pertaining to it.
It's an 89' 4runner, no coils spacers.
I have longer shackles in the back, but springs are sagging so OEM length shocks are fine ATM.
I don't want to order springs, wait a few weeks for them, install them, find the shocks are wrong and wait another few weeks and be down for months.
I'm looking if anyone has any past info with this set-up and can give me some ideas.
If you say they're not long enough, i'll believe you, i dont want to over-extend and rip the shocks apart.
I'm far from a noob, just never seen this setup before...
Old Jul 12, 2011 | 09:19 AM
couldn't find info on what shocks to run with a 2-3" lift ???????? oh boy here we go.........
try here: https://www.yotatech.com/search.php?searchid=8725065
Old Jul 12, 2011 | 09:27 AM
socal85toyota's Avatar
Im running the 10" billy's up front with hoops and 12" in the rear on stock mounts. also running the 4runner ome leafs...they are a little taller than the pickup ome leafs.
Old Jul 13, 2011 | 01:16 PM
hilslamer's Avatar
This is correct - with the OME springs in place, the Bilstiens will limit droop travel, relative to the OME rear shocks. The OME rear shocks compress to close to the same length, but extend further than the sock shocks or Bilstiens, due to differences in internal design.
It depends on how you will be using the vehicle, though...losing some droop travel won't be too much of a big deal if you only rockcrawl and will be keeping the stock swaybar in place...however, if you intend to use it hard/fast, the extra droop will be welcome, and similarly, if you use it without the swaybar and need the extra flex/RTI numbers, the extra droop travel will be missed there too.
Old Jul 14, 2011 | 12:15 PM
When i click the link it gives me some error.
I found lots of stuff on 90-95 4runners but limited info on the older trucks...
I really just want to know if anyone knows the compressed/extended length of bilstein HD's...
If you guys are saying they are shorter... thanks...
suppra87
Jul 15, 2021 05:15 PM
punks_is_4x4
May 31, 2016 06:03 AM
choppe777
May 16, 2016 08:00 AM
justdifferentials
Sep 5, 2015 06:52 PM
Ryall
Sep 2, 2015 06:48 AM
