Sponsored by: CARiD
new to toyotas
Old Nov 22, 2013 | 07:41 AM
  #161
thefishguy77's Avatar
Wow that sucks I would try and check the fluid level in the tcase before work if possible. Just wouldn't want to be running in 4wd on dry pavement.
Old Nov 22, 2013 | 07:51 AM
  #162
If all else fails just pull your front drive shaft. At least that way you not doing damage on the freeway
Old Nov 22, 2013 | 07:58 AM
  #163
theerroneouspenguin's Avatar
It worked. Put it back in 2h,moved it a tad and it shut off. Sweet.
Thanks
Old Nov 22, 2013 | 08:02 AM
  #164
Awesome.
Old Nov 22, 2013 | 08:40 AM
  #165
Anybody from boulder on here?
Old Nov 22, 2013 | 06:04 PM
  #166
Hey...Can someone help me out??
I need a list of all the crap i need for a sas. I got a guy in NC that has an older truck i can pick from for a very good price.
My truck is a 990 runner with the 3.0. 5 speed. IFS with ADD.
Old Nov 22, 2013 | 06:09 PM
  #167
There are kits out there for SAS projects. Trail gear make a good one I think. This is one of those questions that really has no set answer. But if you read through a few buildup threads you will probably have more info than you want. Chefyota's build come to mind. He does great write ups and has recently done his. So maybe start there
Old Nov 22, 2013 | 06:14 PM
  #168
got a link??
so basically...i use an old axle but all new parts for the rest??
Old Nov 22, 2013 | 06:39 PM
  #169
http://www.trail-gear.com/ifs-eliminator-kit
is this it??
and i meant a link for the build thread
Old Nov 22, 2013 | 06:45 PM
  #170
https://www.yotatech.com/forums/f199/chefyota4x4s-1987-4runner-build-up-thread-210796/
Try that
And yea I think that is one of the better kits
Old Nov 22, 2013 | 07:57 PM
  #171
Originally Posted by thefishguy77
https://www.yotatech.com/forums/showthread.php?t=210796
Try that
Cool deal. Is that the kit I need? And it says I need a long driveshaft. Is that stock from something else or do I have to buy it from someone else?
Old Nov 22, 2013 | 08:08 PM
  #172
You are now asking questions beyond my experience level. I am sure someone else will have your answer
Old Nov 22, 2013 | 08:11 PM
  #173
It's cool.
On the link I sent, it says I need a longer driveshaft, a lift kit for the back and the axle itself. I did some looking and a few sits sell the shafts but they are like 300$. I'd love to be able to pull one from a yard or something instead. Lol
Old Nov 23, 2013 | 09:15 AM
  #174
Just got an offer for a skyjacker steering stabilizer. He says its has loops on both ends. Is that what I need?
Old Nov 23, 2013 | 11:44 AM
  #175
OK. I got the steering stabilizer. It should work. Also got some more stuff.
Off road lights,gear oil, one of those big jacks, switch panel,2 u joints, more tools,antifreeze. Will also be getting leafs all the way around and front shocks. Those come tonight.
Think I did good as seeing I only traded a pipe and grinder for it.
Do anyone know if a suburban 1/2 ton axles would fit the yota? He's got some and would like to tinker with my truck. They fit?
Old Nov 23, 2013 | 05:30 PM
  #176
Anything?
Old Nov 23, 2013 | 06:03 PM
  #177
It will be way to wide on your yota so you would either have to put a fullsize straight axel up front. Or have it cut down to width. I would pass on it unless you are going to go Dana 44 full size up front. Not necessary for strength unless you are going to go larger than 35's. with a lot of horse power.
Old Nov 23, 2013 | 06:34 PM
  #178
Full size straight axle?
And I'm not going bigger then 35s and only HP increase would be from a 3.4l swap...maybe.
Old Nov 23, 2013 | 06:35 PM
  #179
Just stick with a Toyota front axel then
Old Nov 23, 2013 | 06:57 PM
  #180
Cool deal. Thanks for the info.
What about the rears?
