new to toyotas
#141
#146
My cel has been coming on more and more.
When it does come on, I do get a lose in power. Idle will drop to about 500 if im at a stop. Don't really notice a lose of power if I'm driving and it comes on. Happens most of the time in 3rd.
#147
Side note.
Picked up eminems new cd. MMLP2. Its not bad at all to be honest.
Hey...anyone have any off road lights they can let go for cheap? The truck is wired up for them just don't have any. Lol. Previous owner said thy sucked so he took em off.
#148
Well. Have finally decided what my first purchase is gonna be for the yota. A windshield. Mine is so cracked all over I can't go on the highway for fear of it shattering. It creaked and pops a lot. Lol
Found one at the local yard for 75$.
#149
4*4 works. Got a few inches last night and it's still snowing. Took it a and while to actually kick in, but it did. And I think it takes just as long to turn off. Lol
Is there a specific sequence to turn 4*4 off? Or do I just park, put in neutral and put it back in 2h? Cause my light stays on. Idk.
#150
4*4 makes a noise when going above 30 in 4h. Can't really describe it but it sounds like a grinding.
Also, it doesn't help with this slick ˟˟˟˟. I was still sliding all over the place.
#152
#153
No there is a drain hole and a fill hole. FYI always get the fill hole plug out first. It would suck to pop the drain hole just to find out the fill hole plug is stuck. And when you pull the fill hole plug out you should see a little fluid start to ease out if not carefully insert you finger. Watching for sharp metal (ouch). And feel for fluid. If none found you probably found your problem. If the fluid is hammered you probably found you problem. Those are you best case scenarios for a easy to diagnose problem
Good luck
Good luck
#154
Good luck
Good luck
#155
If it looks or smells burnt I guess is how I would describe it. Similar to motor oil it starts out pretty and comes out nasty. But even if it toast and low just getting the fluid level up to where it needs to be would be a short term bandaid. The front diff fluid should be cheaper that the t case fluid. I think. Don't quote me on that I just woke up.
#156
Thanks for the info. I'll check it today.
#159
ADD. I'm gonna by some manual hubs soonish. But yea. I just drove to the store and it down disengage. So I'm heeping it in 4h. I gotta cruise the highway today so I'm gonna need it to shut off at some time soon. Lol
