Sponsored by: CARiD
New guy needs some help
Old Jan 16, 2010 | 05:14 PM
burtonboarder's Avatar
hey guys. i got some issues with my yota, but seein how i usually work on cummins, i'm not sure what to check. I bought it with 30k on a rebuild. when i first picked it up, it would cruise 90 down the freeway no problem. then it would only do 80, then 75, now i'm struggling to do 70. its got new plugs in it, and i'm not sure where to start checkin. any helps appreciated.
Old Jan 16, 2010 | 05:35 PM
yoterr's Avatar
fuel filters? had a bronco that would do the same thing if you "distrurbed all the $*^% in the tank" just keep on gettin slower...and when you post try n explain what the prob is in the thread description
Old Jan 16, 2010 | 07:54 PM
ok will do. where do i find this fuel filter?
Old Jan 16, 2010 | 07:58 PM
wd21_sr5's Avatar
Hows the oil? Mine gas fouls and thins out and I can bairly get to highway speeds at all.
Old Jan 16, 2010 | 08:03 PM
just changed about 1100 miles ago. checked it today and its still the same color as when i dumped it in.
Old Jan 16, 2010 | 08:25 PM
brian2sun's Avatar
Man, there are so many things it could be. We don't even know what kind of truck you have. Engine and tranny type? Did you replace the wires with the plugs? Oem plugs and wires? Clean the throttle body? IAC? MAF sensor? Air filter? Was the engine rebuilt entirely or does the block have all original miles on it?
Old Jan 16, 2010 | 10:05 PM
my bad i shoulda known better than that. its a 87 with a carbureted fourcylinder. it was a complete rebuild. filter is clean. i just need some things to check
Old Jan 16, 2010 | 10:11 PM
Teuf's Avatar
OK tell us symptoms on the road, sputter, won't rev, overheats , etc.
Old Jan 16, 2010 | 10:16 PM
if i don't let it warm up before driving, it acts like its flooding out. then it just won't hold speed on the highway. seems to run alright, just seems to have less & less power
Old Jan 16, 2010 | 10:35 PM
abeD85flatbed's Avatar
check your ignition timing, should be a minumum of 12 degrees adavnced. As well as the throttle linkage to make sure your opening the carb. up the whole way. A compression test will let you know if there is a bigger a problem. If nothing else a Weber carb. really simplifies under the hood and give a nice horsepower boost.
Old Jan 17, 2010 | 05:44 AM
yoterr's Avatar
well. with my carb and a couple of others, the AAP really doesent make a diff if its hooked up or not..the choke makes a HUGE difference when its cold tho...my choke wasnt hooked up and first start it would run like crap and wouldnt really rev without spuddering...took her apart (rebuilt it while i was at it) and fixed the choke, 1000000 times better, also you have to push the gas pedal to the floor b4 u start it to close the choke all the way...so does it run fine when warm or are you saying its just getting slower since youve owned it??
Old Jan 18, 2010 | 08:46 AM
thanks for all the replies. its just getting slower. like around town seems to be alright, but as soon as i hop on the freeway to go to school, it won't hold any speed. i bought a fuel filter today, cause i figured it wouldn't hurt in any case. where is it on the truck? i've looked all over and can't seem to find it?
Old Jan 19, 2010 | 06:10 PM
fuel filter is tucked under the bed right by the tank. stick your head under the front passenger side of the bed and look at the frame mounts. the filter is held in a small bracket attached to front side of one.
Old Jan 19, 2010 | 06:24 PM
ibeamtaco's Avatar
ck valve lash you loose a lot of power if they are to tight or loose and if you don't have any other little probs like stated above filter sparkplugs... do a compression test
Old Jan 19, 2010 | 06:32 PM
Z's Confederate Toy's Avatar
Check the plug gap on your new plugs.
polo451
13
Nov 20, 2016 07:49 PM
RatOmeter
Oct 22, 2015 03:17 PM
coffey50
Jul 28, 2015 10:55 AM
highonpottery
7
Jul 18, 2015 02:48 PM
timmJ
Jul 7, 2015 02:01 PM
