Sponsored by: CARiD
missing link
Old Aug 12, 2009 | 09:08 AM
islandboyjt20's Avatar
missing link
have any of you guys did a missing link set-up on a yota...
or what do you guys think about it...i am allright fabing stuff togther...gust wanna hear about it befor i start buliding...thanks...
Old Aug 12, 2009 | 10:14 AM
tc's Avatar
tc
WTF is a missing link setup?
I've heard of 5-link, 4-link, 3-link, y-link, all kinds of stuff, but never heard that one.
I did a dual triangulated 4link for the rear of my 4Runner ... came out well
Old Aug 12, 2009 | 11:42 AM
4Crawler's Avatar
Is that the double shackle setup:
- http://www.rocky-road.com/zuklink.html
If so, most folks find there are better solutions on the Toyota, notably longer springs. Double shackle may be viable if you have very short springs, like on a Zuk, and have no other option, and can live with their drawbacks.
Old Aug 12, 2009 | 09:15 PM
missing link
has anyone did a missing link on a yota...i am thinking about doing one and would like to know what you guys think about it...i have one on my sami and love it. it has alot of flex...i am thinking the same with my yota...(lots of flex sounds good) do you guys think it will work good...i started the project but now think about it more...
Old Aug 12, 2009 | 09:22 PM
Tofer's Avatar
Sponsor
missing link??
Old Aug 12, 2009 | 09:46 PM
seanmearse's Avatar
This a missing link.
scuba's Avatar
is this one of those patent pending things...?
Old Aug 12, 2009 | 09:54 PM
seanmearse's Avatar
Couldnt tell you. I just saw it, then Googled it. The whole "off road use only on front end" is kind of sketch.
Old Aug 12, 2009 | 09:57 PM
its an extra shackle attached to the top of the original shackle that allows the axle to drop even more...its common on the suzuki's here a link...
i think i am going to do it what i here is that no one did it on a toyota...so i guess ill try...
Old Aug 12, 2009 | 10:01 PM
Tofer's Avatar
Sponsor
got it... NO idea why it would be called a missing link.... when you ADDING something.. yes, it can be done, i have it on mine and i love it.
as seen here
i've always heard of / known it to be called a double or scissor shackle set up
Old Aug 12, 2009 | 10:04 PM
well i think that if you can pin it up and not let it drop when driving on the road it would be okay...we did a missing link on my sami and it does exelent in the trails...
Old Aug 12, 2009 | 10:07 PM
as seen here
How long is your top (drop) shackle?
i am thinking about making it kinda of long to get more flex...you think it will work...
Old Aug 13, 2009 | 07:04 AM
tc's Avatar
tc
Flex, especially dirty hooker droop flex is overrated.
It looks impressive as hell in pictures, but there is no spring force driving the axle down to provide actual traction. The ONLY think it is good for IMHO is to "catch" the vehicle as the weight coes back over to that side to have a more controlled descent instead of just "falling" and then having shock damping.
Old Aug 13, 2009 | 07:24 AM
Tofer's Avatar
Sponsor
i like my dirty hooker droop flex......
Old Aug 13, 2009 | 07:26 AM
Tofer's Avatar
Sponsor
the top shackle is the stock Chevy shackle....i can get meausrements today, but i would guess its 3" eye to eye
Old Aug 13, 2009 | 09:31 AM
tc's Avatar
tc
Note that "dirty hooker flex" is indeed a technical term the desert guys use to describe a lot of poorly controlled articulation - usually in reference to the Ford twin beam suspension that dramatically changes camber angle as the wheels travel, frequently causing them to hook an edge when the suspension is drooped.
Old Aug 13, 2009 | 10:51 AM
their is still traction with thees...not as much as coils but it can go about the same places coils can...(and maby more) haha... hay and thanks Tofer for the pic and info...and what kind of springs do you have on that 4 runner...by the way its nice...
Old Aug 17, 2009 | 06:51 PM
i have pic of my missing link...the shocks are not mounted yet but they will be soon...i just wanna know if anyone wants to see them...thanks guys who responded...
Old Aug 18, 2009 | 04:52 AM
91 4Runner's Avatar
Sure, who wouldn't. Just because this setup isn't for everyone doen't mean someone might not like it/get ideas from it...
Old Aug 18, 2009 | 02:03 PM
pic
cut um to size
notch um
weld um...i used 2inch heavy duty spacers...
paint um green
made new shackles one n a half inch longer than stock...
they work kinda good...hay i got a open diff and a broken front end...(2wd...now if only i had a str8 front...)
some creepy creeper joints would be good in hear...
the front tire is not tucked in...i never lift the truck from the a arm...
ten inches eye to eye...
what do you guys think...
i will try to get a video as soon as i put my motor back togther...doing a rebuild of the 20r that was put in by the previous onwer...go figure...
