Sponsored by: CARiD
on to the lower ball joint
Old Mar 13, 2010 | 02:34 PM
8622rtec's Avatar
so now I'm working on the lower ball joint - seems to be stuck in there pretty good - any ideas on where to go from here?
Old Mar 13, 2010 | 02:35 PM
BigBluePile's Avatar
ah you tried a puller yet?
Old Mar 13, 2010 | 02:39 PM
8622rtec's Avatar
ive been trying a pickle fork - the bottom bolt of the ball joint doesn't thread into the knuckle does it? I already removed the nut there too....
Old Mar 13, 2010 | 02:43 PM
no pickle forks SUCK. No the balljoint is tapered to sit in the hole there.
Get a Tie Rod End (TRE) puller works double duty for ball joints AND TRE's. They're inexpensive too. Make sure that you put that nut back on before you put the puller on. ALSO, sometimes they just don't start coming off and you may have to tighten, tap with hammer, tighten, tap with hammer. Are you using a penetrant?
vital22re's Avatar
totally a bro
bfh right in the sweet spot and it will jump out.
Old Mar 13, 2010 | 02:46 PM
8622rtec's Avatar
thanks guys! i think ill try the hammer first... that i have - just a big smack on the bottom of the bolt id guess... otherwise ill go get a puller...
Old Mar 13, 2010 | 03:18 PM
8622rtec's Avatar
no dice! I can't get it to budge... are you guys able to see the picture i posted?
aowRS
Sep 13, 2017 08:22 AM
Odin
Sep 24, 2015 04:38 AM
JRB4Runner2015
Sep 20, 2015 12:29 AM
Regency
Sep 6, 2015 05:47 PM
