Sponsored by: CARiD
front inner&outer wheel bearings
Old Mar 13, 2010 | 08:41 AM
8622rtec's Avatar
Hi all. Super pleased to have found and joined Yotatech!! I have spent the last couple of weeks committing serious time theft reading numerous forum posts. I'll save the intros and what not until I can get some good pics of my new ride - 86 22rtec pickup. Here's a newbie question -
I'm currently doing inner and outer wheel bearings, axle seals, hub rebuild, lower ball joints..
I have removed the hub body and outer wheel bearing from - Once I remove both bearings (the outer already fell out) what kind of grease is used for the center - of the hub that turns on the axle? looks a lot different than the wheel bearing grease...
Also, does anyone have the link for purchase of a Toyota service manual as the haynes doesn't have any torque specs?
Well if you have made it this far - thank you.
Old Mar 13, 2010 | 08:48 AM
4Crawler's Avatar
http://www.4x4wire.com/toyota/maintenance/front_end/
You can use the same grease i n the locking hubs as the bearings, just a very light amount, like brush on a thin film. You do not want the hubs packed with grease as it can create a suction against the hub gear and keep it from locking or unlocking properly.
Old Mar 13, 2010 | 03:24 PM
8622rtec's Avatar
Unhappy
thanks 4Crawler! I was considering using ATM fluid? ...back to the ball joint...
bigjstang
Jun 2, 2025 03:56 PM
jasonty
41
Dec 23, 2018 01:00 PM
jerusry
Oct 19, 2015 05:28 PM
Sep 4, 2015 09:27 AM
Gamble_STi
Jul 7, 2015 07:54 PM
