i need some oil opinions
just bought a 83 toyota pu
going to change the diff oil tcase tranny filter and oil
was wondering what brand or thickness of oil i need
i live in idaho gets pretty cold here in the winter and hot in the summer
and is synthetic good to go with for an older truck or should i stick with the regular stuff thanks in advance
I'm not sure about what thicknesses you should use, any autoparts store can tell you or the dealer or a manual but as for the idaho part...where are you? I'm in rexburg goin to byuI.
Search will get U a ton of info :-) 1st link is arguably the most comprehensive oil talk forum out there....tons of info. Second is a bit off subject but good info none the less. Synthetics.
http://theoildrop.server101.com/forums/ubbthreads.php
https://www.yotatech.com/forums/show...ght=oil+survey
75w90 for the diffs, xcase, and probally tranny...
AMSOIL.. yes synthetic will be fine there, and will be fine in your motor, but may cause existing leaks to get bigger, some of which you dont even see now. This is because it will clean the slidge off of seals and gaskets, therfore exposing a leak that my have been there but blocked with sludge. Personally I swap everything in all my rigs to AmsOil...
I may get some hate mail for this but I got the cheap stuff from Wal-mart (supertech I think?). I plan on changing it every 30k so I didn't really see the need to put in expensive stuff.
Bob the oil guy even says that if you change your oil every 3k then Wal-mart brand is great.
Besides, I like changing my oil. Gives me an excuse to climb under my truck and look for stuff to mod!
particularly since we are going into winter where regular oils turn to a solid (parafin wax content) at cold temps.
IMO, you get what you pay for....
yourrealdad
Jul 29, 2015 11:08 AM
