How much will gearing (5.29s) help with towing?
If I end up keeping my 22RE and rebuilding/dropping in a new one how much would 5.29s help with towing? According to 4LO.com my RPMs would be as follows with the 5 speed/31s/5th gear:
55 MPH (The fastest I'd ever tow anyway) - 2680
65 MPH (Happy medium cruising speed) - 3167
75 MPH (As fast I've ever gone in the truck) - 3655
These numbers don't seem too out of whack for a truck that will not be a daily driver. I don't have a tach, but again, according to 4LO.com I should be turning at about 3028 RPM when doing 75 MPH. A difference of 600 RPM doesn't seem like all that much? Again though, the truck will be seeing mostly 65 MPH or less. Really though I'm less concerned about how fast I'm turning at highway speeds. Rather, I'm curious to know how much of an improvement I'll see starting with a 3500lb trailer from a dead stop. I should add that if I go this route I'll probably install some sort of low-RPM cam (TRD has one, Crane has one, etc...) and open up the exhaust. Regardless, I know that if I can get 225 ft/lbs out of the 22RE it would be a lot, so I'm looking at gearing as a possible fix.
Sure I get that it's not the norm, but the way I see it if I'm not going to swap something in with more low end power I have to make up for it somehow. I'm just trying to figure out if 5.29s vs. the 4.10s would make a huge difference in towing ability, all other things (tires, engine, load, etc...) being equal.
Do it. You won't be let down. You'll be in the power range for an engine that puts 90hp to the wheels at best.
Oh and, forget getting 225ft lbs of tourqe out of a 22re without dropping 4k into the engine.
Don't mind me-I was looking at the newton meters instead of foot pounds on the Wikipedia page. So given the fact that the stock torque figure is 143 ft/lbs if could get 165/170 it would be a lot...
Is it a single cab truck? I had a single cab(light weight compared to xtra cab or 4Runner) 22re w/ 4:56 and it was a great combination but almost border line to low on the freeway. Maybe if you had 22re 4runner the 5:29 might be good for towing w/ 31"s
Obviously you want the torque. I still wouldnt go any taller than 4:88 with 31"s IMO, but would interested to know what you go with and how you like it.
personally, i would go with 4.88s unless you're planning to put bigger tires on also. i ran 4.88s/31s for almost 2yrs and the truck drove great. on the hwy, RPMs were a little higher than i cared for especially at like 70+mph - with 5.29s, i dunno...might be way too high, but then again i baby my truck when i drive it and usually try not to go past 3500rpms. i did notice a positive change in how the truck drove with a load in the bed. i had much better acceleration from a stop. couldn't say how the truck would react to towing 3500# since i've never really towed anything with my truck and would never think to tow something that weighed as much as my truck since the brakes aren't enough to stop that much weight IMO.
if you go with 5.29s and the same size tires you will notice a HUGE difference in how the truck drives. 4.88s you will still notice a significant difference, but it won't be so much. with 4.88s, you might be able to find a factory-geared diff for a good price, whereas the 5.29s would have to get setup by an installer - and it usually reflects in the price.
good luck!
good luck!
5:29 vs 4:10 would be like... "black and white"
good luck!
good luck!
Good luck though
I thought that the tallest OEM Toyota gears were 4.56s in the automatics? If I could find 4.88s in a junkyard that might sway my decision-is it possible to find these?
Factory 4:88s can be found, not sure of your location but I found a set for $250 front and rear and I'm still kicking myself for not buying them!!!! They are rare but out there. http://www.brian894x4.com/Gearratiosanddiffs.html this site list all the codes to help with your search
I have a mechanic friend who can usually get me work on the cheap from his friends. IE: instead of me walking into the local driveline/transmission/rearend shop and handing them the new gears and the 3rd member, he asks for me because he knows them and I pay a lot less $$$. Good reference on that site though.
pyramid
Jul 30, 2015 10:05 AM
vanion2
Jul 29, 2015 06:17 PM
pyramid
Jul 29, 2015 06:53 AM
coffey50
Jul 28, 2015 10:55 AM
Poncho0206
Jul 10, 2015 06:21 PM
