Sponsored by: CARiD
holley fuel pressure regulator help
Old Nov 21, 2011 | 12:56 PM
creswellhick's Avatar
so i got a holley regulator the 1-4 psi one and am going to install it wed this week now on holley website they say these are pre adjusted to 2.7 psi can i just leave it at that is that good or what just curious about what should be at for my motor since its built if that makes a difference ive also have a 32 36 on it that i had re jetted to stock besides i went one up on the primary idle but anyway engine specs are in my sig thanks
Old Nov 21, 2011 | 01:09 PM
xxxtreme22r's Avatar
you can leave it at that, it's fine.
Old Nov 21, 2011 | 01:15 PM
thanks xxxtreme you always have an answer for me will this help alot on flooding up inclines? well before i do my weber mod
Old Nov 21, 2011 | 01:26 PM
It will help, but it won't prevent it. When I run off-road I drop mine down to about 1.5psi. I run about 3-3.5 on the street. 2.7 psi is fine though. You'll just have to fine tune the fuel mixture a bit after regulating it down.
Old Nov 21, 2011 | 01:31 PM
ive never looked at one before so are they easy to adjust or what
Old Nov 21, 2011 | 01:36 PM
real easy, but you need a fuel pressure gauge on it to know what your adjusting to.
Old Nov 21, 2011 | 01:45 PM
oh ok ill look into one any preferences and ill play with the mixture a lil bit to after wards
Old Nov 21, 2011 | 01:47 PM
summit racing has some cheap reliable ones. 1" or 1 1/2" and I think a 1/8 npt fitting is what you'll need. You can screw it right into the other available port on the regulator.
Old Nov 21, 2011 | 01:58 PM
ok il look into it thanks again
jbv808
Aug 6, 2021 04:47 PM
Doug4320
Mar 24, 2018 10:11 PM
Poppie51
Jul 23, 2015 05:03 PM
v_man
Jul 23, 2015 04:01 PM
Poppie51
Jul 16, 2015 06:16 PM
