Sponsored by: CARiD
gear ratios
Old Nov 13, 2006 | 02:06 PM
racoon's Avatar
gear ratios
i need a front differential,, my shaft is hanging out of it. 1994 toyota pickup v6 dx cab. automatic. i call for help. and they ask me for gear ratio. where do i find it?
Old Nov 13, 2006 | 02:16 PM
Elton's Avatar
welcome to yotatech..... you may have to do a little searching to find out what it is ... it may be 4:10s
Old Nov 13, 2006 | 02:22 PM
KyleT's Avatar
What Shaft Is Hanging Out???
Old Nov 13, 2006 | 02:55 PM
racoon's Avatar
shaft
the shaft going into the front differential
Old Nov 13, 2006 | 02:57 PM
racoon's Avatar
shaft
the shaft. or whatever the shaft bolts to is hanging out of the differential. is that the pinion?
Old Nov 13, 2006 | 02:58 PM
racoon's Avatar
i believe i have 4:30 gear ratio. now i just need to find differential parts.
Old Nov 13, 2006 | 03:25 PM
racoon's Avatar
so what i have learned so far is that the front differential is also called the 3rd member, is that correct? and when i try to find parts do i ask for 3rd member or differential?
Old Nov 13, 2006 | 03:27 PM
racoon's Avatar
may i repair 3rd member? are there individual parts for sale?
Old Nov 13, 2006 | 03:28 PM
racoon's Avatar
is there a repair manual?
Old Nov 13, 2006 | 03:29 PM
racoon's Avatar
hello
Old Nov 13, 2006 | 03:41 PM
AxleIke's Avatar
the third is repairable.
There is a repair manual.
It is not for the faint of heart, or any but the very mechanically inclined
take it to a shop.
Old Nov 20, 2006 | 05:10 PM
toyota_mdt_tech's Avatar
OK, do you have the 31" tires stock? If so, you will probably have the 4.88, otherwise, you have the 4.30's.
On your door jamb, you can find the axle code. It will read:
C/TR/A/TM
Means color, trim, axle and transmission, or will look like:
030/F41/G258/A340F
So your axle code would be a G258. Now calling the dealer can net you an axle ratio, but I have used this exact procedure and twice, it was wrong! So be warned. Based on what I have seen, you should have the 4.88 if you have ther large 31" wheels as stock.
Old Nov 20, 2006 | 05:12 PM
I suspect you mean the RF axle stub. If its popped out, pop is back ASAP or it will destroy the carrier. DO you have a lift? These can pull this stub shaft out. Its only held in place with a circlip. Pop it back in and fill with fluid.
RatOmeter
Oct 22, 2015 03:17 PM
norcal98
Aug 10, 2015 06:20 AM
wolfpackfan33
Aug 2, 2015 03:36 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
