Sponsored by: CARiD
Sequoia keeps stalling
Old Oct 30, 2006 | 09:42 AM
briantp's Avatar
My 2001 Sequoia keeps stalling when idling at stop lights ...any thoughts what this could be?
Old Oct 30, 2006 | 09:43 AM
Localmotion's Avatar
try to get your codes read at advance or autozone
Old Oct 30, 2006 | 10:27 AM
briantp's Avatar
thank you!
Old Oct 30, 2006 | 10:33 AM
2001Millrunner's Avatar
is your warranty still alive?
Old Oct 30, 2006 | 10:41 AM
briantp's Avatar
no....110k miles......
Old Oct 30, 2006 | 03:24 PM
Paul H.'s Avatar
What is your idle speed?
Old Oct 30, 2006 | 05:10 PM
HAVOC's Avatar
Only at lights? How 'bout idling in your drive. Will it stall only with your foot on the brake? Brake booster perhaps?
Old Nov 2, 2006 | 08:15 AM
goldmember_down's Avatar
check ignition system, bad plug, deffective boot on coil--causing arcing (look for a white spot on the boot)
Old Nov 20, 2006 | 05:16 PM
toyota_mdt_tech's Avatar
We have had some compressor seizures on those. Maybe its tight, and when it cycles on, load is too high, stalls the engine? Will it do it if the AC is off and the vent is moved to feet? (keep in mind, AC runs in the 2 defrost positions, even if the AC is turned off) if it is the AC, you can unplug the pressure switch on the AC plumbing to disable it till you get it fixed.
eggens
Oct 27, 2015 03:14 PM
charlie_fong
Sep 27, 2015 10:06 PM
taraf
Sep 25, 2015 02:57 PM
bhaithc
Sep 17, 2015 07:53 PM
4runnerstalls
Sep 17, 2015 10:10 AM
