Sponsored by: CARiD
Gas spurting out below to right of Intake
Old Nov 22, 2013 | 10:27 AM
Mason155lbs's Avatar
So i just got a 86 Runner
after a lot of looking around
and a snow storm
I noticed this morning that Gas is sputtering out of a hole
What is supposed to go into this Hole to make sure gas stays where it is supposed to and so that my truck can have "POWER"
Thanks for helping the noob!
all i can hear is fuel pulse damper
but than again people are telling me that is "IN" the engine thanks
Old Nov 22, 2013 | 11:06 AM
derockus's Avatar
what motor? is it coming out of a hole that's not supposed to be there or a hole in a part? take a picture of the area you think it's coming from.
Old Nov 22, 2013 | 12:03 PM
85toy4runner's Avatar
here is the damper is this where it is leaking its located at the end of the fuel rail , I had to replace mine to.. I got this pic from internet
Old Nov 22, 2013 | 12:16 PM
wyoming9's Avatar
Red face
It will never have POWER it might run good.
There is a hole in the fuel pressure damper when the internals go bad they will leak.
Either that is what is leaking or your fuel rail itself is leaking
Old Nov 22, 2013 | 12:24 PM
SoCal4Running's Avatar
Under the plastic cap on the dampener is a little screw. It may of fallen out but it should not have gas on that side of the diaphragm anyways though.
The one on my 86 started leaking long ago and I went to the junk yard and got one off a cellica I think.
There is a copper gasket between it and the fuel rail and Ive never replaced it with a new one an it seals fine.
Old Nov 22, 2013 | 01:03 PM
yes
ok so can i just get the screw for this??
i have no screw
no cap to cover it
do i need a new damper or what are my easiest options
Old Nov 23, 2013 | 04:26 AM
wyoming9's Avatar
Red face
Some one might have a used one on here for sale or your local yard.
Although going used is a lot like rolling dice.
If no one else has one PM me and I should have one.
Old Nov 23, 2013 | 02:07 PM
the damper online toyota web sites has one for $96.00 here is the part # 23270 42010
this part # 90430 14002 is for top GASKET, PIPE FUEL DELIVARY INLET
this part # 90430 17002 is for bottom GASKET(FOR PULSATION DAMPER HOSE); GASKET, UNION BOLT
but to be safe to make sure this is right its best to call toyota and give your vin number and they can check
Old Nov 23, 2013 | 03:57 PM
$96.00 is exactly why I got one at the dollar wrecking yards.
Think I remember the Corrola one being longer but I just cut some threads off to make it the same length as the 4Runners. Been on for almost 10 years now though so my memory is foggy
Old Dec 1, 2013 | 04:28 PM
file:///C:/Users/Mason/Desktop/leak.jpeg
hopefully that shows up
but that is where the gas is coming out
Old Dec 2, 2013 | 10:44 AM
wyoming9's Avatar
Red face
Is this what you need????
This is the fuel pressure damper
It takes the pressure spikes out of the fuel rail.
Old Dec 2, 2013 | 01:58 PM
that looks about right
i set u pics of the part so let me know what u think
thanks!
Old Dec 19, 2013 | 04:09 AM
thanks!
Got the part
Thanks for the advise!
Blamalam
Mar 12, 2022 07:34 AM
wafoogalla
Nov 2, 2016 11:02 AM
raptor510
Aug 19, 2015 02:15 PM
Tacoma1313
Aug 17, 2015 05:44 PM
