Sponsored by: CARiD
engine removal 94 4runner
Old Apr 8, 2010 | 06:05 PM
yotafella81's Avatar
Hey i just realized i'm in the hijacking the thread, here is my thread link, https://www.yotatech.com/forums/f120...emoval-209155/ please jump to this one for me
Old Apr 8, 2010 | 06:55 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
What I do is drop the front shaft at the transfercase only... Then coat hanger or wire it up out of the way.
Then, depending on AT or 5speed...
Drop the tranny. 8 17mm x member bolts.
Remove the bellhousing bolts... starter...
Jack tranns right back up, and only put 2 bolts back into it. All it's doing is holding the tranny up.
Remove engine.
To put engine in:
put as many bolts as you can in it, then drop the tranny again to put the top 3 17mm's back in...
reinstall 8 17mm x member bolts.
Old Apr 9, 2010 | 01:30 PM
mfwimg82's Avatar
I removed intake and right side fuel rail(left fuel rail with body) left slave cylinder in place clutch will stay with engine . long extensions and swivel socket got top tranny bolts. do not know what they were thinking with starter.
arlindsay1992
Jan 23, 2024 01:34 PM
voiddweller
19
May 2, 2016 09:10 PM
yamaha73
Jun 18, 2015 06:19 PM
JaredL
Jun 16, 2015 04:47 PM
ra72
Jun 16, 2015 11:10 AM
