Sponsored by: CARiD
does it fit into a 1985 4 cyl axle
Old Jul 20, 2009 | 02:06 PM
firsttruck1985's Avatar
i have gear problems does the 6 cyl gear fit to the 1985 4 cyl rear axle ???
Old Jul 20, 2009 | 02:09 PM
DeathCougar's Avatar
Yes, but you need to verify axle ratios beforehand. 1985 was either 4.10 or 4.30, and V6 thirds had many options.
Old Jul 20, 2009 | 02:15 PM
my 1985 gear 4:10
i what it to match the 6cyl with the 4:88
Old Jul 20, 2009 | 02:17 PM
I would stay away from the stock 4.88 third. Its offset, so you can never change your gear ratio or add lockers IIRC.
Old Jul 20, 2009 | 02:19 PM
like the 1989 rear axle ?
Old Jul 20, 2009 | 03:32 PM
camo31_10.50's Avatar
WOW REALLY!?!?!?!..you cant regear stock 4.88's?????..jeez didnt know that..but i guess since i dont ever plan on running anything over a 35..i should be atleast a little bit ok..and i'll probably do a diesel swap eventually..
kinda weird..why cant you regear stock 4.88's??????
Sorry about the thread jack btw!
*EDIT*..seen that you said its offset..lol..nvm bou that question..lol
Old Jul 20, 2009 | 03:34 PM
The cases are offset. The gears are thicker to accomidate this, where aftermarket gear sets are not designed for the offset case.
Old Jul 22, 2009 | 02:15 PM
so i can put in a ring and pinon for a 1989 carrier to a 1985 carrier
Flying91
45
Apr 11, 2024 04:39 PM
jerusry
Oct 19, 2015 05:28 PM
deepmarsh
Aug 6, 2015 03:44 AM
yourrealdad
Jul 21, 2015 11:13 AM
hexrain
Jul 12, 2015 01:13 PM
