Dimming Headlights
Dimming Headlights
So my headlights were dimming and just assumed it was the bulbs. I wanted to buy some good bulbs and bought some piia purple ones. The problem is they still seem to be dim. Would this be a result of a dying alternator?
Thanks!
Thanks!
Now that you mention in the battery kind of old. But should this matter if the car is running? Wouldnt the alternator be charging it therefore it should be maxed at at least while the car is on? No sound system or voltage going anywhere else.
Check the voltage at the back of the headlight bulbs and see if that is the cause of the dimming:
http://www.4crawler.com/4x4/CheapTri...ryBeforeYouBuy
hmm all hondas/acuras of the 90's have these problems, when an accesory put a load on the motor it would dim the headlights, by replacing the battery with a deep cylce this fixed the problem for me.
The idea is you want to measure he voltage under load. If you unlug the connector and measure, of course you will see the full system voltage, as no current will be flowing.
