Sponsored by: CARiD
Difference between 22r & 22re
Old Mar 3, 2008 | 10:01 AM
CW's Avatar
CW
Question Difference between 22r & 22re
Is there a difference in short blocks?
I have a 90 4runner with a 22re thats noisy in the bottom end. So far all i have found affordable that runs good in my area is a mid 80's 22r. Will it work if i use a 22re head, intake, etc?
Old Mar 3, 2008 | 10:05 AM
saitotiktmdog's Avatar
No it will not work unless the engine is after 1985. In 1985 the engine changed. The block is taller on your 1990 and the head is shorter. If the engine is 1985 or newer you are ok. Otherwise you cant do it.
Old Mar 3, 2008 | 10:18 AM
CW's Avatar
CW
Hmmm? I have now found two but they are both 84's.
Old Mar 3, 2008 | 10:35 AM
CW's Avatar
CW
Will the long block work if i use my efi intake?
Old Mar 3, 2008 | 10:37 AM
DeathCougar's Avatar
No. You cannot use the 84 engine in you 1990.
Old Mar 3, 2008 | 10:48 AM
CW's Avatar
CW
Ok thanks.
Old Mar 3, 2008 | 10:52 AM
You could always rebuild the one you have. Ted from engine builder has complete kits for around 300 bucks. Look into that. Where are you located.
Old Mar 3, 2008 | 11:32 AM
CW's Avatar
CW
Im in Penticton BC Canada.
Old Mar 3, 2008 | 12:35 PM
leiniesred's Avatar
Nope. Can't bolt your EFI intake to the 22R. Square holes on EFI, round holes on carbbed, 22R head.
Keep looking for a 22RE.
Old Mar 3, 2008 | 05:33 PM
JohnnyRanger54's Avatar
no bueno senor'.... CHINGA CHINGA CHINGA!!!!!
Old Mar 30, 2008 | 03:27 PM
My99's Avatar
Just curious, since I think I may be in the market for a block - How can I tell if a block is a 22R or a 22RE? Also, I'm assuming that as mentioned earlier, an 85+ 22R is an acceptable block? How would I tell the difference between an 84- and an 85+?
Thanks,
KYle
cars-guy
Aug 16, 2020 06:59 AM
dumpster84
Apr 30, 2016 06:03 AM
deepmarsh
Aug 6, 2015 03:44 AM
cars-guy
Jul 11, 2015 07:51 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
