Couple Lift questions
Hey, i have a couple lift questions. First off from my research it looks like a 3" sup lift and stock gears should be good for 33s, is that right?
Next for the rear is blocks, shackles, or add a leafs better? I think add a leafs will make the ride stiff, i thought i heard something bad about shackle lifts, and I’m not sure i like the idea of my axel sitting on blocks... so which is best?
And also what brand is best, Hi-jacker, pro-comp, day star, rough country, or another?
Thanks for any help.
ok one more question. w/ a 3" lift should i get a diff drop? i understand it helps the drive line angles but isn't it good to have your diff higher off the ground away from rocks?
so i got coil spacers and put um on... and i noticed when the truck was jacked up the wheel is actually being held up by the brake line, does this mean i need to get longer lines? i'm guessing thats what i need i'm just supprised it doesnt tell you in the lift instruction that you need um... seems kinda important.
ok another question, it said to get longer shocks, so i got SkyJacker Nitro 8000's, not with truck on flat ground they are almost the whole way in, like maybe could compress anothe 3" max... do i need to get shorter shocks? also i only got about 1 1/2" of lift in the rear so should i just maybe do 1" shims? would that help? one more thing. the springs are now flat, not bowed down... maybe thats how they have been... didn't really look before but shouldn't they be bowed down? maybe i need new springs but i didn't think a 98 would sag that much... any ideas would be great. Thanks
ok 2 more questions. With the lift an the new rear shocks, the shocks are compresed to about 2-3" of the max, ie a load that made the truck squat 3" would compress the shocks all the way, should i get shorter shocks?
also the lift leaveled the truck, i kinda liked it with the rear a little higher, can i just add a 1 1/2" block? will that interfear with the parking brake cable? anyother ideas?
Thanks.
Thanks.
Thanks.
Thanks.
- http://www.4crawler.com/4x4/ForSale/...mTaperedBlocks
And you can extend the e-brake levers if needed:
- http://www.4crawler.com/4x4/ForSale/...rakeExtensions
ok, also i will need longer u bolts and an angled block to keep the drive shaft in line, right? i see that your prices very, how much would it be for what i need to lift it 1 1/2"? thanks for your help.
Likely no pinion angle correction needed unless it is currently off or you have swapped in a CV driveshaft in back (or are running a 2-piece/center bearing shaft):
- http://www.4crawler.com/4x4/CheapTri...FixingProblems
Block options below:
- http://www.4crawler.com/4x4/ForSale/Shims.shtml#FAQ14
Price would depend on what width you wanted, 2" or a wider spring-wide block.
Flying91
45
Apr 11, 2024 04:39 PM
coffey50
Jul 28, 2015 10:55 AM
icentropy
Jul 14, 2015 10:23 AM
