check engine light
check engine light
bought 99 runner about a month ago..everything has been fine until now...we were going through the mountains and the check engine light came on and the engine started shuttering...its the first rain i have drove trough but suspect that doesnt matter...tm is thanksgiving so its going to have to wait to be checked out..from what ive read it could be o2 sensor, maf,the afm... any suggestions would be great? does autozone still do free code checks?thanks in advance
it finally stoped raining.so the plan is to do a tune up.spark plugs,wires,coil,air filter,clean the maf sensor...anything else i should do?...i have 3 days before i go back to work and would like to fix the problem before having to commute...i went to an autozone said they stopped doing free code checks...at the moment i cant afford to take it in, but to do the work myself..thank you for the fast response...
engine light
today i replaced the plugs with ngk plat g power,new air filter and tm, fuel filter...cleaned the map sensor electrodes...reset computer...engine light is off for now...well see what happens...
hopefully the problem is fixed.. havent test drove yet but the idle smoothed out.. when parked..if i remember correctly the last time it acted funny. it was raining as well...is there anything i can do to prevent this from happening again? should i go ahead and do the fuel filter anyways as a preventive measure?thanks again
well i did a full diagnostics scan everything was great exept the o2 sensor...
took 5 mins and pures like a kitten now..coil that i replaced was not the problem so i took it out and used that money for the o2 sensor...thanks everyone who had advice...toyotas sure are easy to work on compared to some big 3 models...next is new timing belt and water pump to ensure im on my way to 400k + miles...
Jun 1, 2021 01:51 PM
