Sponsored by: CARiD
can someone enlighten me? IFS outers on an SA
Old Jan 26, 2011 | 08:03 PM
YODA34's Avatar
alright so i have searched and cant find anything and ive been allover the site for a while now.
my question is about ifs outers on a solid axle after a sas. how does it work and does it give you the same track width. when i do a sas i would rather not run spacers personal prefrence.
i read somwhere on here about this but i cant seem to find it and searching hasnt turned anything up i posted in this section as to not be yelled at by easily iratables with newbs. haha.
any help would be appreciated. sorry for spelling. if its to bad. haha.
thanks yall in advance.
Old Jan 26, 2011 | 08:08 PM
MaK92-4RnR's Avatar
get an FJ60 axle
Old Jan 26, 2011 | 08:46 PM
YODA34's Avatar
what is the difference in the axles. besides the length of the axles.
and the reason i would rather not have wheel spacers is i have heard they are dangerous for dd.
Old Jan 26, 2011 | 09:12 PM
Jaino240's Avatar
You can swap in the IFS hubs in place of the solid axle hub.
Old Jan 26, 2011 | 09:14 PM
Jaino240's Avatar
Ahhh... found this thread for you. Goodluck
https://www.yotatech.com/forums/f31/...spacers-59071/
Old Jan 26, 2011 | 10:12 PM
BLKNBLU's Avatar
Some stuff from Pirate that looks sketchy and another thread from the same guy as linked above with better pics. I'd swear there was a good write up of this on off-road.com years ago but darned if I can find it.
http://www.pirate4x4.com/forum/showt...light=Kamirtoy
http://nissan4wheelers.com/eve/ubb.x.../m/95810621521
Old Jan 27, 2011 | 01:45 PM
YODA34's Avatar
thanks you guys for the replys. i shouldve worded my search alittle diferently and i probly would have found that thanks again.
but now seeing that it kinda makes me nervous for a daily driver.
now has anyone ever swapped both axles out of an 84 or 85 to get the same track width? or am i trying to solve a problem i should just learn to live with.
Old Jan 27, 2011 | 09:59 PM
Jaino240's Avatar
Havent seen any one swap both axles, but I wouldnt see why not. It seems like a good idea if you dont want to run spacers. If you can live with your truck being narrow, then go for it. I personally would swap the IFS parts over to not have to run spacers.
Old Jan 28, 2011 | 03:52 PM
YODA34's Avatar
i might just go that route it will give me a chance to build both axles while still drivin the truck. and they are only like an inch or to shorter so it shouldnt look gooffy should it?
Old Jan 28, 2011 | 06:32 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Originally Posted by MaK92-4RnR
get an FJ60 axle
Why? Lol, a 60's R&P is just a smig larger than 8"
And weighs a bit more...
In a nutshell YODA34, here's your answer
You gain 3" of wheel track b/c the mounting surface the studs go through are farther out on the spindle.
...But this requires you to mount the caliper OUT SIDE the bosses or "ears" you normally bolt the caliper to, only on the inside.
Old Jan 28, 2011 | 08:12 PM
c0ugar69's Avatar
yea I have been searching on this too as I am in the process of building a front axle for my 89 runner, You just swap the hub to the ifs hub and then mount the fj60 or 80 not sure which rotor to the back. and move the caliper to the inside, looks better than running spacers. another option that i have read is use the ifs hub and them a 97 tacoma 4wd rotor over it like most cars the wheel actually tightens against it to hold it on and mount the caliper on the inside also. use a v6 caliper in both instances.
kawazx636
Oct 6, 2021 03:03 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
Badlander
Oct 10, 2015 08:05 PM
dirk89
Oct 1, 2015 05:15 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
