Sponsored by: CARiD
Caliper Upgrade Question
Old Sep 25, 2009 | 04:44 AM
Adh007's Avatar
I read here that the V6 pickups had larger calipers than the 4cyl, so I snagged a pair from a 1990 V6 4wd at the local pick and pull to mount on my 93.
I went to put them on last night and I can't see the slightest difference between the two other than the numbers in the casting.
Is this actually an upgrade?
Old Sep 25, 2009 | 05:29 AM
waskillywabbit's Avatar
V6 calipers have 4 large pistons.
4cyl have 2 small and 2 large pistons.
Old Sep 25, 2009 | 05:30 AM
TNRabbit's Avatar
Unless yours were already upgraded. The V6 calipers have 4 pistons.
Old Sep 25, 2009 | 05:37 AM
RustBucket's Avatar
Look up calipers of different years in the RockAuto.com catalog. It will tell you exactly what size pistons they used. The 93+ ones (I think) had even larger pistons than the earlier V6 calipers, but I'm not sure that they fit.
Old Sep 25, 2009 | 05:44 AM
TNRabbit's Avatar
My piston is bigger than yours~ hahahhahahahahhahahahaha
Old Sep 25, 2009 | 06:05 AM
Adh007's Avatar
What you just said is the limits what I found, but I can't tell a difference, visually, between the calipers and I wanted to know if there was a way to distinguish them just by looking.
Research on other sites would tell me that the bigger calipers have the S12W casting number. I guess I'll look at the casting numbers and measure the piston diameters when I get a chance.
Old Sep 25, 2009 | 06:22 AM
muddpigg's Avatar
You are probably going to need to upgrade vacuum assist booster and mastercylinder, steel brake lines will help too. Been planning on this for awhile myself, don't like my brake feel neither.
Old Sep 25, 2009 | 06:27 AM
Adh007's Avatar
I haven't been so concerned with feel as with stopping power! I'll do one piece at a time, if the calipers don't get me there, the master cylinder is still at the yard... for now.
Old Sep 25, 2009 | 06:45 AM
RustBucket's Avatar
The smaller (4cyl) calipers have one large and one small piston per side. They are different enough to be noticeable.
http://info.rockauto.com/getimage/ge...9/19826-01.jpg
Old Sep 25, 2009 | 07:07 AM
Adh007's Avatar
According to Rock Auto, the part numbers for calipers from a 1990 V6 4wd and my 1993 4cyl 4wd are the SAME.
They don't look like the ones in RB's link. They look to have 4 equal size calipers, 2 on each side. And the castings have some fins. I'm thinking I've got another set of what I already had.
Old Sep 25, 2009 | 07:32 AM
BigBluePile's Avatar
http://www.pirate4x4.com/forum/showthread.php?t=770289
Here's what the old calipers look like. Granted they came off a SFA, but those calipers were what my IFS 4cyl calipers looked like. I upgraded to V6 calipers that I got out of a junkyard and rebuilt them using the above as a guide(https://www.yotatech.com/forums/f116...ebuild-186747/).
Old Sep 25, 2009 | 07:37 AM
muddpigg's Avatar
Well you could search. This has been covered before. Feel of when you push the brake and the vehicle don't stop fast enough and you start looking for where you can swerve to miss the car in front of you. Good luck.
Old Sep 25, 2009 | 07:39 AM
Adh007's Avatar
The calipers on my 4cyl and the calipers I took from the 6cyl both look like this:
Old Sep 25, 2009 | 07:45 AM
Then either somebody upgraded for you OR they started coming that way. Regardless, you should get the dual diaphragm booster. That was the biggest improvement in the brakes for me.
Old Sep 25, 2009 | 07:48 AM
myyota's Avatar
My 86 4Runner has a solid axle swap, can i swap the larger calipers on to it with the stock rotors ?, or would i need to swap the rotors out for the vented later model rotors ?, i already have a brake booster and master cylinder from a 93 4Runner on my 4Runner and it did make a diference, but im always looking to improve things.
Old Sep 25, 2009 | 07:52 AM
Adh007's Avatar
I'm the 2nd owner, and the PO didn't mention any brake upgrades. That, and the fact that the part numbers match at RockAuto would make me think that it came off the line that way.
Interesting. Looks like I've got some nice calipers to sell.
Old Sep 25, 2009 | 08:41 AM
muddpigg's Avatar
Your going to need to swap in vented rotors from a landcruiser or modify the front so the it can run the IFS rotor and hub. This will require you to switch the way your calipers mount so the will bolt to the outside of the axle mounts. I don't really like the looks of the last set up. You can get the LC vented rotors $40ish for two.
Old Apr 27, 2010 | 09:38 AM
yodamudstar's Avatar
i have a 86 pu and my caliper looks just like that and my stopping power is poor will the v6/t-100 rotors and calipers match up with my 4x4 if so what year do i wanna get?
Old Apr 27, 2010 | 10:24 AM
DeathCougar's Avatar
Did you read this whole thread? And follow the links?
Old Apr 27, 2010 | 10:46 AM
yeah i did. did you see anything stating specific years... and i asked my own individual question... his is a 90 mines 86 and i dont see any links other than the ones under peoples names i dont mean to be rude but it seems no one really trys to help on this site only correct people or spelling
