brake problem sm1 may know?
i lost all brakes yesterday. they just went to the floor. so i bled them, little bit of air but not much. an peddle still going to the floor there is nothing happpening. 75 series landcruiser 92 mod 4.2 diesel. any help would be great. thanks
There isn't any fluid loss because your master cylinder failed internally. There are a couple lip seals inside the master cylinder that provide the pumping action when you push the brake pedal and if one or both get damaged your pedal will go right to the floor. Under no load, such as for bleeding, it may pump fluid. Once under a load the fluid will move right past the seals and no brakes will be applied. This is the most likely scenario.
jasonty
41
Dec 23, 2018 01:00 PM
skoti89
Sep 11, 2015 07:46 AM
Johntom240
7
Jul 13, 2015 12:18 AM
Jnkml
Jul 6, 2015 01:20 PM
