Sponsored by: CARiD
Blown HG 93p/u
Old May 8, 2013 | 07:40 PM
  #41
bruno4turbo's Avatar
you want the #1 and #4 up. also when putting the dist back in, I did it very last, have the crank and cam set, everything bolted down. mark on the cam gear should be a 12 o'clock, mark on the dampener pulley at the 5 (theres numbers on the oil pump housing) you want to set the timing with crank and cam before you put the rocker arms on, and the chain. to put the chain on i used a small pry bar (large flat head screwdriver) to over come the tensioner and slid it on the cam.
when you're pretty much ready to run it, to slid the distributer in set the rotor at 12, and when it slides in it will move to about the 10 spot (#1 plug wire) have the bolt that holds it down in the middle and in loose, so that you can change the timing advanced or retarded accordingly
Last edited by bruno4turbo; May 8, 2013 at 09:22 PM. Reason: typo on the piston #'s
Old May 8, 2013 | 07:47 PM
  #42
as for the AC you should be able to just take it off, oil cooler? only oil coolers i know of are for automatic transmissions which are under the radiator. most automatics tcase will have an aux oil cooler for the tcase. but those lines wouldn't be any where near the AC compressor or the lines
Old May 8, 2013 | 07:51 PM
  #43
AndyKrashYota's Avatar
isnt there 4 marks on that pulley tho?
Old May 8, 2013 | 07:55 PM
  #44
Ok so the AC unit is goin BYE BYE
Old May 8, 2013 | 08:01 PM
  #45
there should only be 1 notch on it, use white out to make it pop out more. but there shouldn't be more than 1. also when setting the timing make sure you're not 180degrees off
Old May 8, 2013 | 08:03 PM
  #46
would it be noticable when installing to be 180 off
Old May 8, 2013 | 08:19 PM
  #47
when setting the timing you want it at TDC compression stroke, theres also TDC for the exhaust stroke, hence 180 degrees off
Old May 8, 2013 | 08:37 PM
  #48
I hear ya, so if #1 & #3 are at TDC doesnt it mean that 2&4 TDC would be the 180 on timing?
Old May 8, 2013 | 08:56 PM
  #49
4 stroke engine: intake v, compression ^, power v, exhaust ^.
( "v" piston going down, "^" piston going up)
TDC for compression and exhaust is the same on all 4 pistons, but the cam sprocket mark will be at the 12 o'clock spot for #1 TDC (when the head is on)
Old May 8, 2013 | 08:57 PM
  #50
compression and power the valves are closed, intake the intake will be open, and exhaust the exhaust will be open.
Old May 8, 2013 | 09:10 PM
  #51
toyota4x4907's Avatar
Originally Posted by bruno4turbo
you want the #1 and #3 up.
#1 and #4.
Old May 8, 2013 | 09:11 PM
  #52
Arrg. i figured thats what ya meant. hahaha i got 2stroke on the brain
Old May 8, 2013 | 09:19 PM
  #53
Originally Posted by toyota4x4907
#1 and #4.
yea, sorry the numbers are right next to each other
Old May 8, 2013 | 09:22 PM
  #54
Haha. Something would be awfully wrong if #1 and #3 were up at the same time.
Old May 8, 2013 | 09:24 PM
  #55
haha yea that wouldn't be good at all, damn typos killing engines virtually haha
Old May 8, 2013 | 09:27 PM
  #56
Awesome so, 1 and 4
Old May 8, 2013 | 09:31 PM
  #57
You would have figured it out either way. #1 cant be up without #4 being up as well. Same goes for 2 and 3 together.
4banginRunner
Nov 13, 2015 05:23 AM
83yotastockR
11
Nov 10, 2015 06:54 AM
smilen724
13
Nov 8, 2015 04:11 PM
alexcarey
Oct 14, 2015 06:05 PM
Toys4parts
Sep 26, 2015 01:56 PM
