Blown HG 93p/u
When i do hit trails its because i got the bikes packed or am going camping. I would like to build a baja brush guard for it. I built one for my s10 i had a while back and it looked awesome
Only time i really go offroad is when i have the bikes packed up or im going camping, i roll with my re-tread tires that are 265-75-16's. i wouldnt mind building another baja brush guard like i had on my s10
usually for camping we take my mom's (f250 quad cab) or dads (Explorer) trucks (depending on who i go with), more space for the family to go. i wanna take my truck on a camping/wheeling trip but with school and transmission trouble i haven't got around to it
#26
don't have to loosen the cam bolts, i didn't. as for torque specs heres all of them so you have it all covered
(all measured in foot pounds, small numbers convert to inch pounds)
intake manifold bolts/nuts.......14
exhaust manifold bolts/nuts....33
camshaft bearing cap bolts.....14
cylinder head bolts................58
camshaft sprocket bolt..........58
crankshaft pulley bolt............116
timing cover bolts -8mm ...9 -10mm...29
oil pan bolts.........................9
oil pump mounting bolts (a) top bolt, apply sealer to the end..18 (b) 2 long..14 (c) 2 bottom short..9
good luck!
(all measured in foot pounds, small numbers convert to inch pounds)intake manifold bolts/nuts.......14
good luck!
#27
Head bolts are torqued to 58 ft/lbs tq in 3 passes. It has been recommended to torque them to 60-64, though. I did 60 both when I replaced the HG and after rebuilding the engine in my 4Runner.
Torque sequence:
10 4 2 5 7
8 6 1 3 9
Torque sequence:
10 4 2 5 7
8 6 1 3 9
#28
summer usually I have to work, and right now being full time student I gotta wait for my week off then we're hitting the lake for a couple days. my boyfriend and his family have race boats (1000+ horse power) so that'll be fun haha
#32
ok. new questions. I put the new timing gear and chain on, water pump is in. My question is do i use rvt when i install the head gasket? Also, i used a lil rvt on the timing cover to "keep the gasket from falling out" when i was putting it all back together. Is that Ok? Other than that i just need to scrape gaskets off the head and put her back together
#33
I use RTV in place of the timing cover gasket. Just use the gasket(s) to know where to put the RTV. Then, while putting the head back on, put a dab of RTV at each corner ( supposed to be Toyota BLACK, but any high-temp stuff will be fine)
#35
Its to help keep the seal between the two. On the first HG I ever did, I put RTV around the top of the timing cover where the head mates to it and a dab at each rear corner. Then the second one I did dabs at all 4 corners and one on each side in the middle (someone else's vehicle). While rebuilding my own 22re, I just did 4 dabs at each corner. 5K miles and no leaks.
#37
to get carbon off soak in coolant, and use a sponge to try and scrape it off. or buy carbon removing chemicals. as for cleaning it doesn't have to be perfect, a little within the dome won't hurt it as long as the valves can seal properly and the spark plug wont get dirty.
#40
So there was an AC pump installed at one point and it doesnt work. theres plumbing leading to inside the cab. i already gutted the pump from the engine bay. Can i remove the ac radiator and plumbing or should i just leave that stuff in there. Honestly i want it out. Or is the thin radiator in front of the main an oil cooler?
