Sponsored by: CARiD
BJ spacer with aftermarket A-Arms
Old Jun 22, 2010 | 08:32 AM
lx504life's Avatar
I have a 1991 toyota pickup 4x4 with a BJ spacer kit and a set of aftermarket a-rms(upper) and I have an ailignment issue. Its been aligned but they cant get it right anyone had problems with their aftermarket a-arms? Can you use them with out a lift? Whats the advantage of having them? Any ideas
Old Jun 22, 2010 | 09:04 AM
scuba's Avatar
What "aftermarket arms" do you have ?
Also, this is not offroad tech. This has to do with your specific vehicle and it's suspension/ alginment.
Old Jun 22, 2010 | 12:51 PM
lx504life's Avatar
I searched all over the a-arms and I can't find any name or markings as to what company made them. All I know is they were on there when I got the truck as well as the bj spacer kit. They are red in color.
Old Jun 22, 2010 | 12:58 PM
MaK92-4RnR's Avatar
they're rancho control arms. and they should have nothing to do with effecting your alignment. what kind of condition are your tie rods and idler arm?
Old Jun 22, 2010 | 01:17 PM
4Crawler's Avatar
Might also try another alignment shop. Sometimes the big chain places with the fancy computers take one look at a lifted truck and either say it can't be aligned or if one little thing is out of spec they throw their hands up. A good alignment guy can work with what he has and adjust the rest of the settings to make it work.
My VW has one alignment spec a little out of range, but the shop that did the alignment compensated for that and it has been fine for the last 9 years, drives perfectly straight, no uneven tire wear, etc.
Old Jun 22, 2010 | 02:06 PM
lx504life's Avatar
I appreciate all the help guys I'm about to put some new tires on it but I want to get the alignment squared away before I put them on.
Old Jun 22, 2010 | 03:39 PM
scuba's Avatar
Read this thread https://www.yotatech.com/forums/f123...d-lift-212909/
That may be the brand lift you have.
And I agree with 4Cralwer. Find a different alignment shop. I shy away from the chain places because they want to get it back to what their book says is stock specs. My junk is lifted and it ain't goin back to stock specs. A good alingment guy knows how to align it so the tires will wear properly and uniformly.
Old Jun 22, 2010 | 05:05 PM
Mud Mut's Avatar
I work at a shop where we do alignments and as someone said make sure your tie rods and idler arms and ball joints are all good. Half the people that come in I will not align their stuff because of worn out parts. once it is all fixed there should be no problem geting it all within spec. you can do this at home insted of takeing it somewhere that might not be conserened with checking.
kawazx636
Oct 6, 2021 03:03 PM
4x4YOTA
Aug 23, 2016 09:08 AM
89YodaRunner
Sep 30, 2015 02:18 PM
crash813
Sep 27, 2015 07:15 AM
Project90
Sep 24, 2015 11:40 PM
