Sponsored by: CARiD
Ask your Aisin manual locking hubs ADD auto hubs questions here!
Old May 18, 2012 | 06:14 PM
  #121
aznetplus's Avatar
So could I for right now before switching out to manual hubs, fix the vacuum lines, find the wire for the 4wd indicator sensor bridge the wires (If I can find) and test the 4wd system.
I do believe your right, to make the switch to the manual hubs and ditch the ADD system.
Thank you for your help.
Old May 18, 2012 | 07:00 PM
  #122
Red Wagon's Avatar
As long as you can engage the transfer case and you still have a drive shaft going up front it should work. Other than the lame add system anyway.
Old May 18, 2012 | 07:56 PM
  #123
aznetplus's Avatar
Hey CDN-SMOKEJUMPER thank you all the info/help.
Just want to make the 4wd system even works, the t-case feels like it is going in and out of the ranges smoothly, there is a front driveline from the t-case to the front diff.
Now if I could just find the indicator sensor wire cut it and bridge it.
Once again thank you for the info/help.
Old May 19, 2012 | 03:23 AM
  #124
Red Wagon's Avatar
Glad I could be a bit of help. That area is all I know about really. My whole front end is still ripped apart waiting for me to get it back together when I get home from the mine.
Old Jul 25, 2012 | 11:34 AM
  #125
StewsRunner's Avatar
Hey I am sure this has been asked before but I plan on switching to manual before winter rolls around and one thing has been on my mind, it may be a stupid question but bear with me. . . One thing I like to do is play in the mud and I like trying it in 2WD first. If I get stuck then I put it in 4WD and wiggle my way out. It is nice not having to get out of the truck just to do that especially when it comes to deep mud or even a big puddle so is it okay to lock my hubs before doing this? Locking them and keeping it in 2 for now? And then just putting it in 4 and I get unstuck without getting out of the truck? Or is it a completely stupid and bad idea and I should be ashamed for even wondering about it?
Old Jul 25, 2012 | 11:35 AM
  #126
xxxtreme22r's Avatar
Nope, perfectly fine to do so. Think about the trucks that have the ADD system, their CV's constantly turn with the wheels as hubs themselves are "locked" all the time.
Old Jul 25, 2012 | 11:38 AM
  #127
Okay, thanks!
Old Jul 25, 2012 | 07:23 PM
  #128
Yotard's Avatar
I leave my hubs locked whenever I know I am going to be going in and out of 4 wheel a lot. Its just nice to be able to disconnect them when I'm not going to be using it and keep the wear and tear of daily driving off those parts.
Old Jul 25, 2012 | 07:27 PM
  #129
Sweet thanks!! My buddy always says that it's a terrible idea to keep them locked while in 2WD, I think that is his excuse so he doesn't have to go in the mud. .
Old Jul 25, 2012 | 09:03 PM
  #130
vang_22re's Avatar
Same here but i think its just cause im too lazy to keep switching them back n forth haha
Old Aug 21, 2012 | 12:43 PM
  #131
UVRUGBY's Avatar
Alright, this is my first truck that has had manual locking hubs. So this is a total noob question. The exterior of the truck has the manual hubs, but the interior has the 4x4 gear lever. Did the 1990 pickup come with the manual hub, or was it installed by previous owner? The truck is IFS.
Old Aug 21, 2012 | 01:07 PM
  #132
4Crawler's Avatar
Likely stock. The hubs lock and unlock the front hubs from the CV drive axles front differential. The 4x4 lever engages and disengages the front drive portion of the transfer case. So hubs unlocked = 2WD no matter what you have the 4x4 lever set to. Hubs locked and you have 2WD in 2H and 4WD in 4H and 4L. Your Owner's Manual will have some basic information on that.
Old Aug 21, 2012 | 01:47 PM
  #133
UVRUGBY's Avatar
Thanks for the good info. Is much needed.
Old Aug 21, 2012 | 05:23 PM
  #134
Red Wagon's Avatar
To tell for sure if it is stock and not an add on is to go under and look for the axle tube. If it is not easy to see a straight tube about a foot long from the diff to your driver side CV you have an automatic differential disconnect. I had one but deleted it. If you look at my build thread you can see what I am talking about.
I added manual hubs and got rid of that crap vacuume system.
Old Aug 21, 2012 | 06:39 PM
  #135
fiasco8's Avatar
I don't have any problems and have manual hubs on my 93 dlx.
I am curious what years came with ADD or if it came with a specific trim or as an options.
Does anyone know this off the top of their head?
Old Aug 28, 2012 | 10:09 AM
  #136
RB_yota's Avatar
I'm about to run a TC gen 2 caddy kit on my 94 runner. I'm keeping my 4wd by swapping in t100 front axles, does anyone know if I can keep the add or if I have to convert to manual hubs?
Old Aug 28, 2012 | 10:18 AM
  #137
4Crawler's Avatar
Not an either/or situation. You can keep the ADD system and run manual hubs if you want. Locked manual hubs are the same as the ADD drive flanges, so if you lock the hubs, the ADD system works like normal. Unlock the hubs and you have no front wheel drive and save wear and tear on the front axle components. Or you can keep the ADD drive flanges.
Old Oct 31, 2012 | 12:54 PM
  #138
zspeed130's Avatar
Does ANYONE sell parts or a rebuild kit for these? I have factory 87 hubs and my spring/lock tab ring whatever thingy is bad on one side. I hate to send the whole set in for a rebuild over that but I cannot find parts anywhere!!!
Z
Old Oct 31, 2012 | 12:57 PM
  #139
waskillywabbit's Avatar
Buy used hubs for spare parts.
No one sells those parts.
Old Oct 31, 2012 | 03:32 PM
  #140
Red Wagon's Avatar
Can you buy them new at all?
