Sponsored by: CARiD
ADD to Non-ADD?
Old Mar 2, 2006 | 08:04 AM
snap-on's Avatar
Ive pulled my lever down to 4hi before when i thought iwas still locked in in the front. (while moveing down the road) nasty grinding noises that remind you very quickly that your hubs are not locked.
Old Mar 2, 2006 | 10:43 AM
runethechamp's Avatar
Originally Posted by tc
OK, I see what you're saying, but since there are no synchros in the transfer case, you'll just get gear grinding like a missed shift - not total catastrophic failure of the entire front drivetrain!
Had never really thought if it - I've always done like Cebby said, leave the hubs locked if you think you might need 4WD.
I'm still trying to get my transfer case replaced by the tranny place that did my replacement when my previous tcase blew because it ran dry. They somehow replaced it with a tcase without the synchros, so now I can't shift into 4wd on the fly anymore
Old Mar 3, 2006 | 07:41 AM
motoracer47's Avatar
cool, guess im wrong on the damage part(luckily i always love to be wrong when comes to breaking something.) i thought the grinding thing was correct, i guess i just thought if you were going fast enough, it could break something, but i was just guessing.
that sucks about the your transfer rune, hopefully they will take care of ya
Old Aug 8, 2006 | 03:58 PM
kwikrnu's Avatar
I have a question about putting a seal in the diff where you did. How does the end of the axle shaft now get lube? I took about my manual diff this afternoon and saw no seal where you put one...
My truck is a 95 tacoma if that makes a difference.
Old Aug 9, 2006 | 02:52 PM
  #25
Twisty's Avatar
?? Not sure ?? I guess the bearing doesn't need lube??....My original manual hubs diff had that seal......so thats why I installed it into the ADD diff when I swapped the axles over. If yours doesn't have one there now, then I would probably leave it out.
Obmi
Oct 4, 2015 11:30 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
Cycles
Sep 29, 2015 06:37 AM
oldblue
Sep 28, 2015 04:07 PM
ktm192k
Sep 24, 2015 03:36 PM
