Sponsored by: CARiD
98 4Runner replaced batt cannot start, headlights work dashlights do not
Old Jul 15, 2011 | 11:41 AM
ericftworth's Avatar
My 98 4Runner battery died and I replace after letting it sit for a month. Now it will not start. The headlights will turn on but the dashboard lights do not come on nor does the radio when in assc mode. Checked all fuses under the hood and under the steering wheel and they all look good. When I turn the key the only sound is a click from a relay under the steering wheel. The battery is working fine as the headlights are glowing to their full brightness. The starter is not clicking only the small relay in the fuse box under the steering wheel. Any Ideas?
Thanks!
Old Jul 15, 2011 | 11:13 PM
myyota's Avatar
Check all of your fuses again, they can look good but be bad. Use a meter to check each one. Check to make there is no corrosion on any of the fuses or the socket they plug into. Also check to see if you knocked any wires loose when replacing the battery.
JF9243176
Oct 8, 2017 04:21 AM
voiddweller
19
May 2, 2016 09:10 PM
marcusSRG
Jun 27, 2015 07:13 AM
Niameyrider
Jun 25, 2015 05:50 AM
gog1968
Jun 22, 2015 05:55 AM
