Sponsored by: CARiD
94 yoda sas questions
Old Apr 20, 2012 | 07:37 PM
Toy-Yoda94's Avatar
Question 94 yoda sas questions
Hello everyone im new to this site bought my 94 last year. i used to have a jeep years ago that i went wheeling in. Anyways i just aquired a maching set of 85 solid axles with 5.29 gears and locked in the rear that im going to put in my 94. what i wanted to know is what is the best sas lift kit to go with quality and performance. im lookin at 6 inches i want to go with 37inch tire so far.. anyone that has done this to there truck info would be greatly accepted
thanks
Old Apr 21, 2012 | 05:21 AM
waskillywabbit's Avatar
Welcome to Yotatech
What you want to do has been done and discussed just a bit.
I'd suggest searching, read, and then ask some specific questions.
:wabbit2:
Old Apr 21, 2012 | 06:15 AM
stngllhm's Avatar
All pro has a really good kit that will include a hi-stear kit as well
Old Apr 21, 2012 | 06:28 AM
StewsRunner's Avatar
No I could be wrong here but if you want 37s you are probably going to need more than just 6in of lift. . .
Old Apr 21, 2012 | 09:47 AM
stngllhm's Avatar
The rear should fit ok and the front may fit since all pro kit moves the axle forward, but also I would get the axle relocation plates to move them further forward
Old Apr 21, 2012 | 11:15 AM
scott90's Avatar
6" springs from all pro would probably clear 37s comfortably,my old roomate had 4" all pro springs with 36's but he did also have a 2" body lift plus depending on how big your shackle you use for your sas in the front it might add a extra inch or so.
Old Apr 21, 2012 | 12:12 PM
I'm sure adding a 2in body lift would do perfectly, sure 37s will fit but when you flex you could run into some trouble so a 6 plus a 2 would probably do the trick
Old Apr 21, 2012 | 06:49 PM
Toy-Yoda94's Avatar
i was accually going to do a 3 inch body lift so i could tuck the transfer case up a bit more for ground clearance. thanks ill check those kits out.
Flying91
45
Apr 11, 2024 04:39 PM
Shagool22
Aug 14, 2015 12:24 AM
HollieJayyy
Aug 9, 2015 07:59 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
