Sponsored by: CARiD
94 3.0 Clutch engagement issues after replacement
Old Dec 25, 2012 | 04:20 AM
jellybean292's Avatar
Have 94 Toyota truck and replaced the clutch and clutch plate and now the clutch wont engage can anyone tell me why? The lines have been bleed several times and still wont engage.
Old Dec 25, 2012 | 07:34 AM
rokblok's Avatar
Jellybean, you don't have to post in every clutch thread you can find. We will answer eventually in one thread. Take a pair of needle nose vise grips and pinch the rubber line between the clutch master and slave cylinder. Don't crank down on it, just enough to close off the line. Try to push in on the clutch pedal. If it doesn't go down, then the master is holding pressure and doing its job. That means the slave is bad. If it falls to the floor, then the seals in the master are leaking and the master is bad. Basically you are testing one or the other.
Don't try to shove the pedal to the floor, just light pressure as if you were shifting while driving.
Old Dec 27, 2012 | 05:49 PM
Was not sure it posted. My husband has bled the clutch. Replaced the motor and this was not happening before. Put in new clutch, pressure plate and throw out bearing and clutch wants to grind a little when trying to put in gear. Only has a little cup to put oil in that goes to a metal line that goes to slave cylinder. There is not rubber line to crimp off. This is for a 94 Toyota 4x4 P/UP 3.0 3VZE. Any suggestions on what to try or do or what could be making this happen?
Old Dec 27, 2012 | 10:33 PM
rokblok's Avatar
There should be a short 6-12" rubber hose in the clutch line. Usually close to the slave(transmission) end, down at the bottom. This allows for engine movement, which is separate from the frame/body of the truck. If you don't have any flexible line between the clutch master and slave, you have other issues. And if its grinding a little when changing gears, that could easily be an air problem. Be sure it's thoroughly bled...
Old Dec 27, 2012 | 11:43 PM
wyoming9's Avatar
Red face
In this day it is so possible to have received the wrong parts in the clutch kit box.
It is also a good idea to just put all new hydraulics when putting in a new clutch.
On some years the rubber clutch hose is above the steel line coming off the slave cylinder looking up follow the steel line you should see it.
There needs to be some flex between the body and the transmission in that line or it will break.
Old Dec 31, 2012 | 09:56 AM
rattlewagon's Avatar
There is also an adjustment nut on the back of the clutch pedal. Worked when I had the same problem.
Old Dec 31, 2012 | 11:04 AM
nvtoyota's Avatar
Had the same problem on my 94 the adjusment on the clutch pedal solved it.
Regency
20
Jan 3, 2020 07:43 PM
voiddweller
19
May 2, 2016 09:10 PM
Dillon1983
Jul 7, 2015 06:47 PM
Jnkml
Jul 6, 2015 01:20 PM
Vargntucson
Jul 4, 2015 12:15 PM
