Sponsored by: CARiD
93 22re starts ok, runs for 3 seconds, runs rough, dies
Old Feb 9, 2019 | 06:55 AM
gasmith's Avatar
Ok everyone. I recently acquired a 93 truck with a 22re. I have done a bunch of looking around the forum at posts like this and havent seemed to find anyone else with exactly this issue. So as the title of the post states, it starts fine, runs for 3 seconds, then starts to sputter and get extremely rough and dies. I tried a MAF and that wasnt the issue. Any feedback is appreciated. Thanks.
Old Feb 9, 2019 | 07:00 AM
gasmith's Avatar
Just to clarify even further, I can rev the engine (its still rough and doesnt run well, but RPMs will increase). The truck will not move though, even with increased rpm.
Old Feb 9, 2019 | 06:05 PM
22BrokeBoyRE's Avatar
Have you taken a look at the circuit open relay? Jump your fuel pump at the obd port. If it runs then the cor is probably bad.
Old Feb 10, 2019 | 05:13 PM
gasmith's Avatar
Thanks. Ill give that a shot.
Old Feb 13, 2019 | 09:58 AM
gasmith's Avatar
Tried that, it didnt change anything. You have any other suggestions?
Old Mar 3, 2019 | 02:25 PM
old87yota's Avatar
Are you still having this problem?
Has this been a problem ever since you acquired this Truck?
Old Mar 6, 2019 | 07:11 PM
gasmith's Avatar
Yes sir, it has. I knew this was gonna be a project truck right out of the chute. Honestly, one of the things Ive always wanted was to have a diesel converted yota, so Ive actually already yanked the 22re that was in it and have begun cleaning and prepping the rest of the chassis.
Old Mar 9, 2019 | 09:37 AM
rlw0766's Avatar
I am having the same problem except my 93 22re doesn't die. the cel comes on and it bogs down n smells like its running rich. Any help would be greatly appreciated.
Old Mar 9, 2019 | 07:47 PM
old87yota's Avatar
The first thing you should do is check the Engine Computer for codes.
To check for codes, find the "Diagnosis" connector by the under-hood fuse box and jump the E1 and TE1 terminals to set the Engine Computer into diagnostic mode. The jumper can just be a paper clip bent to reach to both terminals.
Turn the ignition switch to the "ON" position and count the number of flashes of the check engine light.
Below is the factory procedure for checking codes and what the different codes mean.
Old Mar 10, 2019 | 06:02 AM
rlw0766's Avatar
I have been trying to do that. Once I got it to continuously flash now it wont flash at all. I have put plugs, wires, cap, rotor, fuel filter, changed fuel injectors, fuel pressure regulator, fuel pump relay, ignition coil, temp sensor, afm sensor, tps, fuel pump, n EGR valve. I didn't mind changing all those parts on a 25 year old truck, but I'm ready to get it fixed and just drive it. fuel mileage went from 18mpg to about 10mpg when this started happening.
Old Mar 10, 2019 | 06:05 AM
rlw0766's Avatar
Every once in a while the CEL will go off and the truck picks up and runs great, but just for about 30seconds at a time, and sometimes it bucks with the CEL going on n off.
Old Mar 11, 2019 | 11:08 AM
thefishguy77's Avatar
Take a picture of you jumping the diagnostic ports. Just to eliminate any silliness
Old Mar 11, 2019 | 02:01 PM
rlw0766's Avatar
I just tried it again. I also printed the link someone sent and followed it.
Old Mar 11, 2019 | 05:50 PM
rlw0766's Avatar
I followed that link & it flashed a couple times then quit flashing n stayed on solid again.
Old Mar 14, 2019 | 04:29 PM
Haven't dealt with that one yet. I am sure a few here have.
Old Mar 14, 2019 | 06:36 PM
Co_94_PU's Avatar
most likely not making a good connection in the diagnostics port
Old Mar 14, 2019 | 06:57 PM
rlw0766's Avatar
Thanks, I have tried several jumpers but will look into it more.
Old Apr 26, 2020 | 06:15 PM
rlw0766's Avatar
I ended up finding a used ECU & the truck is running great again. Thanks to all that helped.
owlhowler
Jan 10, 2022 09:05 PM
YakBlack
Jan 11, 2014 12:40 PM
thaddeusss
7
Jan 23, 2013 08:30 AM
Albin
Nov 8, 2011 01:53 PM
