93 22re starts ok, runs for 3 seconds, runs rough, dies
Ok everyone. I recently acquired a 93 truck with a 22re. I have done a bunch of looking around the forum at posts like this and havent seemed to find anyone else with exactly this issue. So as the title of the post states, it starts fine, runs for 3 seconds, then starts to sputter and get extremely rough and dies. I tried a MAF and that wasnt the issue. Any feedback is appreciated. Thanks.
Just to clarify even further, I can rev the engine (its still rough and doesnt run well, but RPMs will increase). The truck will not move though, even with increased rpm.
Have you taken a look at the circuit open relay? Jump your fuel pump at the obd port. If it runs then the cor is probably bad.
Thanks. Ill give that a shot.
Tried that, it didnt change anything. You have any other suggestions?
Are you still having this problem?
Has this been a problem ever since you acquired this Truck? :safari: |
Originally Posted by old87yota
(Post 52419646)
(Post 52419646)
1 Attachment(s)
The first thing you should do is check the Engine Computer for codes.
To check for codes, find the "Diagnosis" connector by the under-hood fuse box and jump the E1 and TE1 terminals to set the Engine Computer into diagnostic mode. The jumper can just be a paper clip bent to reach to both terminals. Turn the ignition switch to the "ON" position and count the number of flashes of the check engine light. Below is the factory procedure for checking codes and what the different codes mean. |
I have been trying to do that. Once I got it to continuously flash now it wont flash at all. I have put plugs, wires, cap, rotor, fuel filter, changed fuel injectors, fuel pressure regulator, fuel pump relay, ignition coil, temp sensor, afm sensor, tps, fuel pump, n EGR valve. I didn't mind changing all those parts on a 25 year old truck, but I'm ready to get it fixed and just drive it. fuel mileage went from 18mpg to about 10mpg when this started happening.
Every once in a while the CEL will go off and the truck picks up and runs great, but just for about 30seconds at a time, and sometimes it bucks with the CEL going on n off.
Take a picture of you jumping the diagnostic ports. Just to eliminate any silliness
Originally Posted by thefishguy77
(Post 52420147)
I just tried it again. I also printed the link someone sent and followed it. |
I followed that link & it flashed a couple times then quit flashing n stayed on solid again.
Haven't dealt with that one yet. I am sure a few here have.
Originally Posted by rlw0766
(Post 52420187)
Thanks, I have tried several jumpers but will look into it more.
I ended up finding a used ECU & the truck is running great again. Thanks to all that helped.
