Sponsored by: CARiD
88 4runner brake problem
Old Oct 7, 2007 | 06:33 PM
Jer455's Avatar
Hi
I have an 88 4runner and i just replaced the brake lines and the master cylinder and now i still have no brakes, i have bleed them several times and still no brakes
any ideas on what i am doing wrong
TIA
Old Oct 7, 2007 | 11:49 PM
Jay351's Avatar
is your booster leaking?
Old Oct 9, 2007 | 06:17 AM
Jer455's Avatar
I am hoping thats not the problem but i think it is
Old Oct 9, 2007 | 06:36 AM
waskillywabbit's Avatar
Did you bench bleed the MC? Did you bleed the LSPV? Any visible leaks? The rear cylinders might be leaking and you cant see them.
Old Oct 10, 2007 | 05:40 PM
FredTJ's Avatar
If the booster is leaking he would have brakes.
It would just be hard to push the pedal.
Fred
Old Oct 22, 2007 | 02:29 PM
Jer455's Avatar
I've have put a new MC, New Booster, New Lines New Break Pads, New rear caliper, and still nothing, seems like there is little presure when i boost it up
i have brake presure intill i hit the gas and then its back to the floor
Old Oct 24, 2007 | 05:19 PM
rickybobby012889's Avatar
My advise would be take the master cylinder off and there will be a push rod from the booster there will be a bolt on it you can adjust back and forth Grab the back of it with vise grips (you will have to the whole thing will turn you will see what iam sayin) and turn it like your taking it off about a 1/4 inch and Id say that will fix your problem PLUS ITS FREE TO TRY IT lol
Old Feb 2, 2008 | 08:11 AM
904Runtampa's Avatar
Did you ever figure it out? I'm still in the same problem...
Old Feb 2, 2008 | 05:49 PM
bigarms23's Avatar
try bleeding the master cylinder first and than the rest of the brakes and this should give you brakes
gillesdetrail
Nov 19, 2019 12:56 PM
toyota32
Jul 6, 2015 05:42 PM
Jnkml
Jul 6, 2015 01:20 PM
CJ94yota
Jul 3, 2015 10:14 PM
