Sponsored by: CARiD
4runner frame
Old Sep 4, 2009 | 07:35 PM
theyellowyota's Avatar
4runner frame
hi im new here and i did search this but i got no pictures and i need a picture if enyone has one of a stock 1990 toyota 4runner rear suspension set up
Old Sep 4, 2009 | 10:17 PM
Matt16's Avatar
What specifically do you need a picture of? I have a couple, but unless the truck is rolled on its side, its hard to get it all in one pic.
Old Sep 4, 2009 | 11:04 PM
i need like a picture off the rear coils and how they mount
Old Sep 4, 2009 | 11:43 PM
Matt16's Avatar
Old Sep 5, 2009 | 07:35 AM
tc's Avatar
tc
What are you trying to accomplish? Putting a 4Runner 4 link under a truck?
IMHO, the factory 4 link setup has several weaknesses that are easily addressed, and one that is not so easily addressed...
- all the brackets hang down. Off the frame, off the axle, everywhere - just waiting to get tagged by rocks
- the lower links are not very strong
- the upper links are very weak
- use of regular bushings limits articulation and smoothness
- triangulated uppers and parallel lowers results in binding
- little triangulation in the uppers requires use of panhard bar
After ripping one of the lower link mounts off the frame, I set about redoing mine to address these deficiencies. It came out REALLY well, and was no more work than installing the factory setup would be.
https://www.yotatech.com/forums/f116...thread-153382/
Old Sep 5, 2009 | 10:43 AM
umm no i just bought a 4runner and its lifted and i was wondering what the people did befor me lift it and how they mounted it all up and i got a question what keeps the axel from droping is it the shocks?
Old Sep 5, 2009 | 10:55 AM
tc's Avatar
tc
Yes, usually the shocks limit the droop travel. There are only compression bumpstops (the rubber things inside the springs)
One thing to watch for with a lot of lift is if they didn't drop the upper panhard bar mount down, the rear axle might be shifted to the side.
Old Sep 5, 2009 | 11:25 AM
thanks for the info it has been very helpful
MMA_Alex
25
Apr 18, 2017 05:07 AM
steve miller
Oct 10, 2015 01:40 AM
Sep 4, 2015 09:27 AM
87turboPA
Jul 9, 2015 05:58 AM
coryc85
Jul 6, 2015 04:07 AM
