265/75/16 Mud Terrains?
Will I have issues with a stock 98runner 4x4? The muds are a lot beefier, and I know that the A/T tires will work, but any experience with M/T tires this size on stock? Thanks!
Good question because the diameter of the LT265/75/16 BFG M/T is 31.9 inches, while the BFG A/T KO is 31.7 inches, according to charts available in PDF format on BFG's website. Good Times, do you mean your M/T's rub "ever so slightly" while you are off-roading or just daily driving? Have you tried your M/T's with a front wheel at full stuff while turning? Can you tell where they rub? I frequently run moderate trails, and I am considering fitting BFG 265/75/16 M/T's to a stock 2000 4Runner next spring, so like Gavin77 I would appreciate any input.
ever so slightly is in full compression / full lock (turning). the likelihood that you'll get to that point is rare. do a quick search for members in the 3rd gen section running those and I'm sure they'll all agree you'll be fine stock. the 265/75 will just fill out the fender and make it look better than the stock 265/70.
good luck
good luck
good luck
good luck
aowRS
Sep 13, 2017 08:22 AM
Toys4parts
Sep 26, 2015 01:56 PM
