Sponsored by: CARiD
265/75/16 Mud Terrains?
Old Dec 12, 2006 | 04:52 PM
gavin77's Avatar
Will I have issues with a stock 98runner 4x4? The muds are a lot beefier, and I know that the A/T tires will work, but any experience with M/T tires this size on stock? Thanks!
Old Dec 12, 2006 | 05:09 PM
Good Times's Avatar
you'll be fine. May rub ever so slightly but we're talking very slightly.
Old Dec 12, 2006 | 07:19 PM
RockyMtRunner's Avatar
Good question because the diameter of the LT265/75/16 BFG M/T is 31.9 inches, while the BFG A/T KO is 31.7 inches, according to charts available in PDF format on BFG's website. Good Times, do you mean your M/T's rub "ever so slightly" while you are off-roading or just daily driving? Have you tried your M/T's with a front wheel at full stuff while turning? Can you tell where they rub? I frequently run moderate trails, and I am considering fitting BFG 265/75/16 M/T's to a stock 2000 4Runner next spring, so like Gavin77 I would appreciate any input.
Old Dec 12, 2006 | 09:07 PM
Good Times's Avatar
ever so slightly is in full compression / full lock (turning). the likelihood that you'll get to that point is rare. do a quick search for members in the 3rd gen section running those and I'm sure they'll all agree you'll be fine stock. the 265/75 will just fill out the fender and make it look better than the stock 265/70.
good luck
Old Dec 12, 2006 | 09:09 PM
Localmotion's Avatar
I had the ATs in the 265/75 flavor on stock suspension and did not rub.
265/75/16 is the way to go with no lift.
Old Dec 12, 2006 | 09:10 PM
TRDatVT's Avatar
good luck
I was running 265/75/16 Wrangler MTR's for a while and i never rubbed unless i hit a rather large bump at full lock. Never rubbed daily driving at full lock even with the truck full. Mounted on a 16x8 with 2" backspacing i believe. Looked nice, ran nice, wore like ÅÅÅÅ. Shouldnt be a problem...
Old Dec 13, 2006 | 03:47 PM
Sdkfz251/7's Avatar
I have 265/75/R16Toyo MT's on my 00 taco and they rubbed a bit. It was more annoying than anything and happened more often when turning right. A 3in lift took care of it.
Ryan
Old Dec 27, 2006 | 12:37 PM
MACKDADDYFREAKNASTY's Avatar
Will 265/75/16 BFG A/T rub on a stock 4Runnner with stock running boards?
Old Dec 27, 2006 | 01:27 PM
Sequoia'd's Avatar
I've got 265/75/16 Nitto Terra Grapplers on '01 Sequoia wheels on my '91 4Runner. No lift, no rubbing!
aowRS
Sep 13, 2017 08:22 AM
Toys4parts
Sep 26, 2015 01:56 PM
tysen86
Sep 25, 2015 11:15 PM
Adam Edgar
Sep 20, 2015 03:24 AM
