Sponsored by: CARiD
1990 4runner questions
Old Apr 20, 2011 | 06:23 AM
Grizzley's Avatar
I have a 1990 4runner and my friend gave me his whole front end off of his 86 4runner. The front end has a 4 inch lift and I was wondering if it would work on my 1990? If it is compatible what could I use in the rear?
Old Apr 20, 2011 | 06:36 AM
camo31_10.50's Avatar
yep, should be no problem.
you can order some 4" coils from alot of places, pro comp, trailmaster, OME i believe as well.
Or you can use FJ80 coils in the rear, those will give around 4" of lift, if you need more add like a 1" spacer
Old Apr 20, 2011 | 06:54 AM
Grizzley's Avatar
Thanks for the quick reply.
Would I be able to only put four inch lift coils on the rear or do I need other things as well?
Old Apr 20, 2011 | 06:57 AM
blue_CA_yota's Avatar
you'll need longer shocks and possibly extended brake lines..
Old Apr 24, 2011 | 04:27 PM
Grizzley's Avatar
1990 4runner rear lift
Does anybody know where I could get a rear 4inch lift for a 1990 4runner that comes with all the brackets needed?
Old Apr 24, 2011 | 04:50 PM
90runnerfan's Avatar
yea get rid of the coil springs and read this...http://www.allprooffroad.com/images/...conversion.pdf .
Old Apr 24, 2011 | 09:36 PM
Grizzley's Avatar
I would love that but don't got the money or tools needed.
Old Apr 25, 2011 | 04:51 AM
rattlewagon's Avatar
Read here:
https://www.yotatech.com/forums/f116...-guide-155339/
Old May 20, 2011 | 01:47 AM
Grizzley's Avatar
tightening front wheel bearing
I took my 1990 4 runner in to get aligned and the mechanic said that I need to tighten my wheel bearings. Can some tell me how to do this because if I let the mechanic do it he will charge me $300. THANKS!
Old May 20, 2011 | 03:14 AM
elblako91's Avatar
300 dollars?!?!?! How much are they charging you to align it?
MMA_Alex
25
Apr 18, 2017 05:07 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
87turboPA
Jul 12, 2015 07:49 AM
madxman21
Jul 9, 2015 10:26 AM
ptb12
Jul 5, 2015 01:49 PM
