How do i replace rear side marker light for a '03 4Runner?
Old Oct 3, 2006 | 02:14 PM
jxd315's Avatar
Question How do i replace rear side marker light for a '03 4Runner?
Hi,
I need to replace my rear side marker light because my wife backed into a fire hydrant and busted it out. I have a 2003 4Runner ltd. I have found the light online, I just don't know how to install it. Is there any electrical hook up for it? Can anyone help me out? Thanks!
Jon
Old Oct 3, 2006 | 03:28 PM
Good Times's Avatar
rear side marker light? Are you talking about the tail light itself? If so, there are 2 10mm nuts holding it in place from the inside of the side panels. There are 2 pop out squares (looks like 3" x 4" rectangle) that you can pop using a flathead located at the back of the inside cabin. Inside the panel you'll find the 2 nuts that needs to be popped out.
If this is not the piece then please take a picture of what light you are referencing and we'll gladly help you out.
Thanks!
Old Oct 4, 2006 | 05:00 AM
jxd315's Avatar
Thanks for the info. I am posting a picture of what i am talking about. one picture is the busted light and the other one is the good one. I noticed that there are only electrical wires running to the tail lights and not the rear side marker lights... is this correct? Thanks!
Jon
Attached Thumbnails How do i replace rear side marker light for a '03 4Runner?-img_1779-small-.jpg   How do i replace rear side marker light for a '03 4Runner?-img_1780-small-.jpg
Old Oct 4, 2006 | 05:11 AM
lee's Avatar
lee
arent they just reflectors?
Old Oct 4, 2006 | 05:23 AM
jxd315's Avatar
That is what i thought, but I wanted to double check.
Old Oct 4, 2006 | 06:40 AM
Jared's Avatar
Yeah, in the USA market they aren't used. I wish they were, but they aren't.
Old Oct 4, 2006 | 09:55 AM
Good Times's Avatar
those are indeed just reflectors. You can easily replace them by just going under the bumper and reaching to it. I believe it is attached by 2 10mm bolts (I can't recall). Should be a relatively easy fix.
Old Oct 4, 2006 | 09:56 AM
jxd315's Avatar
Sounds easy enough! Thanks for all your help!
Old Oct 7, 2006 | 06:21 AM
Sharp4runr's Avatar
They are just reflectors, but they can be easily made into running/turn/brake lights: http://www.toyota-4runner.org/showth...ght=bumper+mod
I've got them as running/brake lights on my truck and it looks awesome. Anything to make my truck a little more visible while commuting through the DC Metro area is a good thing and it doesn't cost much (less than $25)
BTW, I think it is just 1 10mm nut holding the housing in place. Get under the bumper and you'll see it.
gillesdetrail
Nov 19, 2019 12:56 PM
voiddweller
19
May 2, 2016 09:10 PM
merc1100sc
Jun 26, 2015 05:24 PM
cchinny
Jun 25, 2015 08:11 PM
