Concerned?
7 Quarts???? I couldn't fit that many in if I HAD too.
You need to go back there and raise some hell about that, because you flat out got robbed. They of all people should know EXACTLY how much oil goes in the motor, and it's not anywhere near 7.... just think, you now have an extra half gallon or so of oil in places you really don't need/want it to be.
Now that's worse than putting the 5W-20 oil in it. I think this really could cause a nuclear war.....
Untill you drain it out, and put the correct amount in....
I change my own oil in my '04 Runner ever since one skid plate bolt disappeared and another was stripped. 6 quarts of 5W30 and a new oil filter after I use the strength of ten men to get the damned filter off. I put them on myself too. I turn it until it is hand tight then 1/4 turn. When I go to remove it it has sucked in and is almost impossible to turn. Is there a fix for this? Anyone else have this problem? Other than that I love this vehicle.
TheBFA
Feb 15, 2020 06:55 AM
