Writeup: removal of third and locker install
BIG 10-4! on using the rubber vacuum caps....I do that all the time....they work perfect for that application. As far as the locker being noisy during coast....that doesn't sound right. The only thing I can think of that could do that is different tire diameters....try a tire rotation and see what happens. It's also possible you have a sloppy driveline....pinion is a little loose and clunks back and forth and is aggravated by the near 1/4 turn of typical locker play. And yes, a heavier oil will quiet up the click-click noises from lunchbox lockers.
Matt16---You did such a nice job of 3rd member removal/Aussie install that when I get home in a couple hours I will add this thread to one of my Aussie install links. Your write-up will 'enhance' or give a breathe of fresh air to my Aussie install link. I might put your write up on this one shown near the bottom of this page....
http://aussielocker.com/install.php/TM7c35fd/f8a2/.html
ZUK
ZUK
I should clarify that the locker makes noise when it coasts with the clutch in around a tight corner. Same noise as when you do the locker test to see if it is working. I'm sure its a normal noise, at least for those of us with 5 spds.
I think this is because of the inherent play in between inside couplers in the locker itself and the crosspin when there is no torque being transmitted from the driveshaft. In the absence of torque, the inside couples can move back and forth a bit and the ouside couplers can engage the inside coupler quick enough to make a click sound. When under power, the speed at which the teeth engage is dependent on wheel speed instead of the the force applied by the springs between the inside couplers. If you are lost, worry not, I would be amazed if anyone understood what I was thinking here.
Maybe this will help, should anyone wonder what I'm talking about:
I've got some 80W140 in there, the noise is so quiet that no one but me has ever noticed, except in a echo-y parking garage.
#27
the ol "same thread bolt drum undoer thingy" that didn't work no more than fly to the moon! ahhahah I torqued on it a few turns and the metal tore away.
Got the third out anyway. Now I have to find a new drum
#28
#29
I've been wanting to put the aussie in my 94' pickup for a while but ive never once worked on a diff and really dont know all too much about basic mechanics quite yet. would it be recomended that i pay someone to install it or is it easy enough to figure out in a weekend for an ignorant newbie? any words of advice would be completely appriciated.
#31
Thanks to the authors and contributors of this thread. My Aussie came in yesterday and I'm looking to install at the earliest opportunity, perhaps this weekend.
I've read through the documentation here and for the most part it makes good sense. I have a couple of questions.
1) How can one determine if the thrust shims which are to be reused with this install are suitable or if new ones are required?
2) I see in Zuks nice write up that he "snugs" up the adjusters on a higher mileage rear end. http://www.gearinstalls.com/aussielocker.htm If anyone has some guidance as to how to do this without Zuk experience, I'd like to hear how I could safely accomplish the same thing, as I suspect my rear end had seen well over 130k miles.
jerusry
Oct 19, 2015 05:28 PM
coffey50
Jul 28, 2015 10:55 AM
crashburnoveride
Jul 10, 2015 06:39 AM
