Worst thing imaginable ..
Old Jul 16, 2013 | 12:14 PM
Smilemon's Avatar
Glad to hear that it is starting. Never trust a cold engine though, let it warm up to operating temp and see if it still dies out on you.
Old Jul 16, 2013 | 03:19 PM
Edionne13's Avatar
Thanks for that tip! Jw but is there any difference between a v6 or 4banger AFM?
Old Jul 16, 2013 | 03:21 PM
Smilemon's Avatar
I'm a carb guy, so I can't help you there. Maybe someone else knows, or Dr. Google always has the answer.
Old Jul 16, 2013 | 09:24 PM
Edionne13's Avatar
Well I have my v6 one numbers are the same on the one I bought but that was crap also. Thengrabbed a 4banger one from buddy the part numbers are different so I won't check. Planning to grab one off a 91 4runner tomorrow morning everything should work out.
Old Jul 16, 2013 | 11:12 PM
  #25
wyoming9's Avatar
Red face
It might as long as the next one is good.
Then it just might fix your #24 code as well!!
Old Jul 16, 2013 | 11:38 PM
  #26
toyota4x4907's Avatar
v6 and 4cyl AFMs are not interchangeable.
Old Jul 17, 2013 | 08:44 PM
  #27
Edionne13's Avatar
Well check engine light gone. The junk yard people said out in the original air filter. He said they'll go bad and not a really much gain in these engines? I didn't do what he says I could care less. Gained my power and feel the engine again doesn't bog or take long to accelerate anymore "like it has to think". Thanks for your help guys now I just have 3 AFM's...
Old Jul 18, 2013 | 05:40 AM
  #28
AdmiralYoda's Avatar
My head is spinning trying to read through the over auto-corrected broken engrish so this may have already been said.
Looks like the AFM was your problem. Just remember that the ECM will not turn the fuel pump on until it has a valid signal from the AFM. So if your AFM is screwed then it will just crank over forever.
And on the octane booster. 7-10 points does not get you from 87 octane to 94-97 octane. It gets you to 87.7-88.0. And I'm sure even if you put 110 octane in your truck it would be fine. If you don't believe a spark can ignite it... drench yourself with 110 octane gas and light a match to see.
Just kidding....don't do that.
Old Jul 18, 2013 | 06:30 AM
  #29
Edionne13's Avatar
Thanks for that early morning laugh
Old Jul 18, 2013 | 01:57 PM
  #30
Edionne13's Avatar
Error code 17? Awesome another issue
Old Jul 18, 2013 | 02:12 PM
  #31
Edionne13's Avatar
Yep it blinks once pauses then blinks 7 more times. I haven't found what it means yet just replaced the AFM no cat valve cover gasket just replaced
Old Jul 18, 2013 | 02:37 PM
  #32
gigatech88's Avatar
f system is operating normally (with no detected faults), the CHECK ENGINE light will blink continuously
and evenly about 2 times a second.
Otherwise, the light will blink a number of times equal to the trouble code as follows:
The light blinks only (.5 second ON, .5 second OFF) when indicating a number.
The light will be OFF for 1.5 seconds between the first digit and the second digit of the code.
If more than one code is stored, the light will be OFF for 2.5 seconds before the next code is displayed.
Once all code(s) have been displayed, the light will be OFF for 4.5 seconds and then the whole sequence will repeat.
There is no code for 1 7
Old Jul 18, 2013 | 04:05 PM
  #33
Edionne13's Avatar
So what your saying here nothing is wrong it's just gonna stay on?
Old Jul 18, 2013 | 04:29 PM
  #34
gigatech88's Avatar
Possible you misread the code. Ill check alldata when I go to the shop. But I'm pretty sure there's no 1 7
Old Jul 18, 2013 | 07:03 PM
  #35
Edionne13's Avatar
Okay I'm not seeing a 17 at all ill check it again may take a video and post.
Old Jul 18, 2013 | 07:10 PM
  #36
gigatech88's Avatar
If it's a 7 your seeing I think v that's your tps. To lazy to look it up
Eggslinger
Jun 8, 2019 03:32 PM
dumpster84
Apr 30, 2016 06:03 AM
Yotadawgjr
10
Aug 23, 2015 10:51 AM
Dakotaneu
Jul 27, 2015 12:03 AM
HookahRoo
Jul 20, 2015 07:06 PM
