Won't turn over - help asap?
Old Mar 28, 2009 | 12:45 PM
86tuning's Avatar
Starter failure comes in two popular flavours:
1. multiple clicking from the starter due to inadequate voltage or current flow
2. single click from the starter due to worn out contacts and plunger.
It's possible for the motor to die as well, but this doesn't usually happen until the third or fourth set of contacts.
Old Mar 28, 2009 | 12:51 PM
hostile's Avatar
I believe #2 is my problem.. an even bigger problem is just the fact i can't get the damn bolts loose on the starter. I have to head to work so i've given up for today. Thanks everyone for all the help so far.
Old Mar 28, 2009 | 03:38 PM
Jay351's Avatar
Bolts are easy. One is easily removed from the front of the truck, with about 2ft of extensions.
The other is easily removed after removing the access panel in the fender well, and using a 8" extension or so.
Hardest part of the whole R&R process for me, was getting the inner stud/nut (came out all together) threaded in. I have big hands and big arms!
Old Mar 28, 2009 | 04:06 PM
874runnersr5's Avatar
Yeah true, the hardest part is putting it back in, very awkward area lol
Old Mar 29, 2009 | 01:10 PM
  #25
hostile's Avatar
Putting the new starter in wasn't much of a problem but it's still doing the same thing so the starter wasn't the problem. =/
I'm open to new suggestions.
So far i've:
cleaned the battery posts and wire connections with a wire brush
followed all ground wires and positive wires coming off the battery to make sure they're connected
checked fuses
checked starter relay
replaced starter
also tried jump starting it
All my electrical works but i turn the key and it just clicks once and doesn't make anymore noise.
Old Mar 29, 2009 | 01:14 PM
  #26
4Crawler's Avatar
Always worth a quick voltage check to see if the problem is in the starter or the wiring upstream from there:
- http://www.4crawler.com/4x4/CheapTri...shtml#EasyTest
Old Mar 29, 2009 | 01:49 PM
  #27
hostile's Avatar
I forgot about the voltage meter, i'll have to go pick one up. Ours is on my parent's boat in stockton, ca so it's of no use. Thanks
Old Mar 29, 2009 | 04:36 PM
  #28
wyorunner's Avatar
where does it sound like the click is coming from?
Old Mar 29, 2009 | 05:21 PM
  #29
hostile's Avatar
It sounded like it was coming from the starter but i've found the problem. It was just bad wiring to the starter so the starter wasn't getting enough power. Probably got wet the last time i played in the mud.
Thanks everyone for all your help and thanks for the web references, 4crawler. Walk-through's with pictures really helped me identify what i was looking at.
Old Mar 29, 2009 | 05:32 PM
  #30
wyorunner's Avatar
well thats good to hear, now the truck runs again.
Old Mar 29, 2009 | 07:14 PM
  #31
hostile's Avatar
One more thing though, there is little black rubber tubes that come out of the starter's vent hole. Is that small piece necessary? Mine fell off when i was putting it in and i can't get it back on. lol
Old Mar 30, 2009 | 11:37 AM
  #32
4Crawler's Avatar
Mainly there to keep dirt and water out of the drain hole.
Old Apr 1, 2009 | 08:40 PM
  #33
hostile's Avatar
Yeah, i figured but is it the end of the world if mud just so happens to "splash" up into the little hole?
lol, my truck tends to find it's way into mud holes.
Old Apr 1, 2009 | 09:26 PM
  #34
iamsuperbleeder's Avatar
could shorten the life of the starter if water, or more so dirt and sand, find their way in there
I'd try to just snag and pocket one off any starter in a junk yard
IIRC, they just kinda push and pop right in
Old Apr 1, 2009 | 11:05 PM
  #35
hostile's Avatar
well i have one but i couldn't get it to pop back in while working in that tight space. I'll give it a try friday when i have a bit more patience and don't have work.
Old Apr 1, 2009 | 11:20 PM
  #36
sinneDBTB's Avatar
definately elec. man, check your dist. cap, rotor and wires, igniter, ign. coil... do all the basics first like slingblade would.
mine used to do that and then the power would go out and i'd have to go shake the wires around at the batt. - have you looked at your alt. yet?
Old Apr 1, 2009 | 11:25 PM
  #37
sinneDBTB's Avatar
oops didnt see the second page...
okamikai
Apr 30, 2018 10:19 PM
trucker trash
Jul 28, 2015 10:09 AM
yourrealdad
Jul 21, 2015 11:13 AM
Hamonacracker
Jul 17, 2015 08:33 AM
raiderhawks00
Jul 8, 2015 06:23 PM
