wont change gear Auto box on 3vze
Old Apr 14, 2009 | 01:42 AM
philmoon's Avatar
Please please help me fellas I have a 92 plate 3vze and some times it wont change gear first thing in the mornings this seems to be connected to the fact that the speedo is intermitant first time its started but I dont always get both together sometimes just have speedo issues !!!
The gear box was fully rebuilt only 5 months ago and was fine for first couple of months but has been in the mud since !!
Also sometimes its the gear is slow to engage as in park to reverse or first.
but all oil levels are good and other than that it seems tip top any clues cos i cant get to work at the min cos it took 20 mins to get into 2nd today.
Thanks in advance for your thoughts
Old Apr 14, 2009 | 06:12 AM
mt_goat's Avatar
My guess is a shift solenoid is sticking. Did they replace all the solenoids while it was being rebuilt? That's a common practice by a good rebuilder because they are a common problem and things as small as lint from a rag can cause problems with them. If there was a failure of the tranny bad enough it needed a rebuild there might have been debri going though the tranny and/or ATF cooler. How's the color of the ATF? Was there any warranty with the rebuild? If so, take it back!
Old Apr 15, 2009 | 12:32 AM
philmoon's Avatar
there was a warranty but its too far really for me to travel its like 500 kms away you dont think its to do with the speedo then ???
Old Apr 15, 2009 | 04:00 AM
mt_goat's Avatar
It's possible, I'm no expert
Old Apr 26, 2009 | 11:30 PM
philmoon's Avatar
have had a thought the gear box has a speedo sensor on the rear and the speedo has gotten progressivly worse over past couple of months am wondering if maybe the oil seal is worn ??? Seems to have trouble selecting gear when pointing up hill for the first time I drive it sensor at the back of the gear box..
Also I have a front Automatic disconnecting diff ??? what does this do ?? I know have normal one works but what is the advantage of A.D.D.
Old Apr 27, 2009 | 04:37 AM
mt_goat's Avatar
There is a speedo sensor at the rear for the speedometer and a speed sensor inside the tranny for the ECU. The one inside controls the shifting.
Old Apr 27, 2009 | 01:41 PM
mt_goat's Avatar
http://www.4x4wire.com/toyota/tech/add/
Old Apr 30, 2009 | 02:29 AM
philmoon's Avatar
thanks for that explains alot lol !!! lol
Jun 1, 2021 01:51 PM
mskalmus
May 28, 2017 07:51 AM
Jnkml
Jul 6, 2015 01:20 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
wilbertd
Jul 6, 2015 07:39 AM
