windshield wiper arm removal?
Old Jun 19, 2007 | 01:04 PM
Jay351's Avatar
I wanted to take mine off to paint the skinny part of the wiper arms since the paint has come off and there is surface rust on them.
I took off the 12mm nut and washer but the arm wont budge, is there a little clip in there or is it just seized up?
I will spray some deep creep in there and check back here..
thanks
Old Jun 19, 2007 | 02:44 PM
Elton's Avatar
just wiggle it a little more it will come off
Old Jun 19, 2007 | 03:54 PM
Jay351's Avatar
Im scared Im going to break somthing, the drivers side won't budge at all and the passenger side will move up 1/4" and then stop, like its binding on somthing...
just wanted to make sure that it will come off..
I bought some liquid wrench, see if that helps it.
Old Jun 19, 2007 | 04:23 PM
foot0069's Avatar
Tap on the top of the stud with the handle end of a screwdriver. While you pull straight up on the part that wraps around the stud. Be sure you arent pulling at an angle. PBbaster or somesuch for a day first is a great idea too. If the cap has been on there it should'nt be too rusty.
Jim
Old Jun 19, 2007 | 11:48 PM
toy4run's Avatar
a mechanic buddy of mine said that there is a wiper arm puller that you can purchase. He said just use a small pulley puller and it will come right off.
Old Jun 20, 2007 | 02:22 AM
TomThumb's Avatar
Just wanted to make sure you pulled the wiper arm away from the window. There is a lot of temtion from the spring and it will bind on the stud. Mine wouldn't buge till I tilted the wiper arm up, then it just fell off with the nut removed. I know its' a little simple but just wanted to make sure that wasn't your problem
Old Jun 20, 2007 | 05:46 AM
ewong's Avatar
Spray on some PB Blaster.
Let soak for 30min or so
Flip up the arm so that the wiper points OUT.
Use a brass bar and bang on the stud and on the side of the arm.
Not gently taps but not enough to bust it off.
Pull on the arm "out".
The puller is usually a "battery terminal puller". I gots one but never tried it onthe arm as the above worked fine.
Old Jun 20, 2007 | 06:19 AM
aviator's Avatar
WD 40 will work too
like folks said flip the arm up first then tug straight out from the stud wiggling as you go. Mine were all siezed on at first too but about 10/15mins. of effort got them loose... while they are off take the opportunity to lube the linkage as well some water got into my driver's side stud and was enough to freeze the whole mechanism... I used LPS4 to lube the thing... took a few applications but it works now...
Old Jun 20, 2007 | 08:37 AM
Jay351's Avatar
thanks alot guys, will try again this afternoon
Old Jun 20, 2007 | 10:19 AM
89truck's Avatar
I just painted mine last week. I used Deep Creep, wrapped a rag around the arm by the stud, and pulled with a pair of channel locks. Came right off. Like someone else said make sure you pull the blade away from the window.
Old Jun 20, 2007 | 11:52 AM
dijlop's Avatar
certainly dont use channel locks and push towards the window. probally wouldnt be healthy.
Old Jun 20, 2007 | 08:02 PM
89truck's Avatar
Nope pull them off the stud not pry.
Old Jun 24, 2009 | 06:15 AM
pwd's Avatar
pwd
Bump on this, I'd love to paint my wiper arms too. Any luck with this Jay?
EDIT: Just went out and unbolted them. Requiered some wiggling then they came right off no problem(with the arms folded up).
Old Jun 24, 2009 | 10:32 PM
isaac338's Avatar
Those wiper arm pullers are only about ten bucks - use the right tool, don't pry on them with channel locks or screwdrivers.
Old Jun 24, 2009 | 10:55 PM
Matt16's Avatar
Mine pulled right off. Might have coaxed it a bit with a screwdriver IIRC.
Old Jun 25, 2009 | 11:29 AM
Jay351's Avatar
I ended up painting them while they where on the truck, but that its starting to come off...
I never bothered to try again, but il give it another shot. I have a small gear puller I can use.
okamikai
Apr 30, 2018 10:19 PM
rusty904
Mar 27, 2017 05:20 PM
mussy01
Dec 13, 2016 08:20 PM
corey519
Aug 12, 2015 11:12 AM
msane99
Jul 17, 2015 10:13 AM
