Why is my xfer case shifter off
Old Jul 28, 2009 | 10:32 AM
1985yoda's Avatar
Hey guys just bought an 86 xtra cab 4x4. I was told it had an auto and was swapped over to a 5spd from another 86. Now this is my 5th toyota 4x4 and all of the others the 4wd shifter sits straight up and a little towards the driver. Mine faces the passenger side dash. When i put it in reverse it hits the small shifter. Any ideas?
Old Jul 28, 2009 | 10:36 AM
algranger's Avatar
Might just be because you have a different tcase, were any of your other Toyotas the same tcase? Also if it has a body lift someone might have done a little ghetto fabrication on the shifter
Old Jul 28, 2009 | 11:19 AM
1985yoda's Avatar
I was wondering if the transfer case could be different from what came in the truck. It just doesn't look like it should be leaned over towards the glove box. Are there different transfer case options in those years. OH yea no bodylift on the truck
Old Jul 28, 2009 | 11:35 AM
algranger's Avatar
I'm not sure what years held which tcases but i know they changed a lot through the years
Old Jul 28, 2009 | 11:38 AM
AxleIke's Avatar
I have a top shift tcase, and it points over towards the glovebox. It does get whacked by the shifter occasionally.
Old Jul 28, 2009 | 11:47 AM
Junkers88's Avatar
X2 here. Both my 86 pickup and the 89 4runner do this.
Old Jul 28, 2009 | 12:04 PM
4Crawler's Avatar
Maybe try pulling the shifter and then turn it 180 degrees and stab is back in and see if that is any better. Otherwise, you can bend it to a more upright orientation. Marlin does this with a length of pipe that drops over the shifter, just long enough to fit in the cab and then gently bends it into the desired position.
Old Jul 28, 2009 | 12:14 PM
1985yoda's Avatar
Yea thats what i was thinking about doing is trying to bend it. Just never seen one like that before. I guess its from the swap
Old Jul 28, 2009 | 12:26 PM
ozziesironmanoffroad's Avatar
i know the tcase changed between 1987 and 1988... i had to do a little minor fabbing when i swapped my cab after a roll.
Old Jul 28, 2009 | 02:14 PM
dropzone's Avatar
Fossilized
just be sure to pull it like 4crawler suggested, do not attempt to bend it when it is in the TC.
Old Jul 28, 2009 | 03:01 PM
Plumbrbob's Avatar
I bet you have a g-series transmission with a forward t-case
I have had this problem in my old 87 22r
the problem was the shifter seat and socket was worn
Old Jul 31, 2009 | 05:14 PM
Jay351's Avatar
Bend the shifter to clear. Easy.
zytra
Jan 24, 2019 03:16 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
Phantez
Sep 30, 2015 08:24 AM
Toys4parts
Sep 26, 2015 01:56 PM
toyotasaurus
Sep 24, 2015 03:30 PM
