Where to buy the Idle Air Valve Coolant Hoses
Old Oct 1, 2015 | 05:50 AM
kcaudill's Avatar
The truck :
1993 Toyota pickup dlx extended cab 4x4 22re
I would like to replace the coolant hoses from the bypass to the Idle Air Control Valve. Other than the dealership, dose anyone know where to buy them? Advance, autozone, Napa and other just scratch their heads when i ask them for the part.
thanks
Old Oct 1, 2015 | 07:36 AM
scope103's Avatar
http://www.toyotapartsoverstock.com/...rimLevel=18290 $38 and $21, if I have the right one (that's why you have a camera ....)
"Auto parts stores" are in the business to sell as many parts as they can, but don't want to carry a lot of inventory. Brake pads, for instance, are a maintenance item (they are regularly replaced) and fit lots of different vehicles, so there is an aftermarket supply and a good market to resell them.
Your hoses fit a handful of 20+ yr-old vehicles, and are generally NEVER replaced in the life of the vehicle.
Of course Advance, etc. is not going to carry them.
Old Oct 1, 2015 | 10:06 AM
kcaudill's Avatar
Wow thanks for the find, Didnt even think of looking there. And these things must be made of gold to sell for $70 geezzz
Old Oct 1, 2015 | 10:50 AM
scope103's Avatar
I don't have any idea how to DIY a molded hose, so they were probably all manufactured in the 90s and have sat in stock every since. Somebody has to pay for that storage space.
Old Oct 1, 2015 | 11:08 AM
Janos01's Avatar
Either of those auto part stores should have aftermarket or be able to fabricate hoses as well.
Old Oct 1, 2015 | 11:26 AM
scope103's Avatar
Originally Posted by Janos01
Either of those auto part stores should ... be able to fabricate hoses as well.
How does that work? I thought molded hoses were formed from UNVULCANIZED rubber, then heated in a mold to permanently vulcanize it. What auto part store can do that?
Old Oct 1, 2015 | 11:54 AM
wyoming9's Avatar
Red face
I have to wonder about his posts at times.
If you want to replace those hoses if you put some thought into doing it I have used the Blue Silicone Hoses you just need to make them long enough so they don`t kink .
If you want the stock hoses better grab them now who knows when the last one gets sold.
Old Oct 2, 2015 | 12:30 PM
Janos01's Avatar
A auto part store should have both molded aftermarket (more expensive) or as I said be able to fabricate hose as OReily's has rolls of rubber tubing that can be cut for various lengths.
Old Oct 2, 2015 | 01:57 PM
wyoming9's Avatar
Red face
If you are so sure Please Post the part # I am sure I would buy a few sets of molded hoses to fit the 22REC engine.
The OP was talking about direct replacement hoses.
So Please Please post the part # so we can all go buy a set.
Old Oct 5, 2015 | 07:34 AM
kcaudill's Avatar
What ^^^^^ said
Numbers please
Old Oct 5, 2015 | 08:23 AM
Janos01's Avatar
As far as direct replacement, to me that sounds like the dealer. Otherwise, may I ask why you (wyoming9) and scope are backing me into a corner?
I was trying to post helpful information. If it was not, oh well.
Old Oct 5, 2015 | 09:06 AM
scope103's Avatar
... may I ask why you (wyoming9) and scope are backing me into a corner?
Let's not get too touchy. Your posting was very clear: aftermarket molded hoses for 22-year old trucks DO exist, and simple corner parts stores CAN fabricate a molded hose.
First, if there is a source for such aftermarket hoses, we'd all like to hear where that is. I'm pretty sure it's not Autozone, Napa, O'reilly ....
Second, it now sounds like when you said "fabricate hoses" you meant to say "cut off a piece of stock hose." Those aren't the same at all. For this particular hose a piece of stock SILICONE hose might work, sorta. (wyoming9, and others, have tried it) But most molded hoses have pretty sharp bends in them, and if you tried to substitute stock hose they would kink. (I've tried.)
We all appreciate attempts at helpful information. But if you're not sure about your information, you should be prepared for people asking "how, when, where?" Particularly when you say something very clearly ("This part is available at this store.") when you have no real reason to believe it's true.
But if you were offended, I apologize for causing that.
Old Oct 5, 2015 | 01:07 PM
wyoming9's Avatar
Red face
If you can`t run with the Big Dogs stay on the Porch
We all live and learn every day
Old Oct 6, 2015 | 06:24 AM
kcaudill's Avatar
Lol i just wanna buy and replace hoses not open up can of worms. I guess i will suck it up and buy the $70 for 2 hoses.......
Old Oct 6, 2015 | 07:37 AM
wyoming9's Avatar
Red face
That is the trouble the worms get left in the can to long
They need to get out more often
Maybe with video games no one plays Poker in real time !!
Sometimes you get called to show your hand.
I thought your question was pretty straight forward
Old Oct 8, 2015 | 03:43 AM
854x4's Avatar
I just did this on my 88 and all these hoses fit great, I had to shorten the 18021 but other then that no problems. Also the 18222 hose is the one that people always have trouble finding its the one that goes from the fitting next to the thermostat housing to under the throttle body. The fitting is 90 degrees on 85-88 and straight up on 89-95 but this hose will work for both. Everything was purchased from rockauto. You might not need the 18223 hose since you should have the newer style iacv on your 22re. 85-88 3 hoses 89-95 2 hoses.
Gates part numbers
for 5/16 hoses
18222 - Throttle body to thermostat fitting
18223 - Throttle body to iacv
18021 - Iacv to bypass bolted to back of timing cover
1/2 hose
18400 - Timing cover to bottom of lower intake
Old Oct 8, 2015 | 04:47 AM
Terrys87's Avatar
Thanks ^^^^ I just added those to my parts page for a quick reference.
Old Oct 8, 2015 | 05:21 AM
kcaudill's Avatar
Yeah i try to be very direct and to the point so no misunderstanding what im trying to ask. But somehow someone always skews on a tangent, lol. I guess there is always that ONE GUY. lol
Old Oct 8, 2015 | 10:28 AM
wyoming9's Avatar
Red face
For sure and I work at it every day!!
Old Oct 10, 2015 | 02:39 PM
19934X4's Avatar
I have a 1993 Toy 4x4 PU that I am the original owner of. The PU has been sitting for 2 years. The PU has 115K Original Miles on it.
I want to get this thing back into safe driving condition. The truck starts with a jump, drives but sounds a bit off. It's carburated etc.
I need to drive it from Sac over the Tahoe Forest pass to Reno about 150 miles but fearful of it dying. It has had fuel sitting in it for 1 year. What do I do? Also where do I start by getting this truck back into decent reliable condition? The vehicle is clean meaning no rust damage or beat run damage but there's lots of moving parts that have not moved. I do not want to take it to a dealership for an overhaul. Any experts in this really cool type of vehicle? Thanks
smthwsn357
May 1, 2024 07:28 AM
Eggslinger
Jun 8, 2019 03:32 PM
Poncho0206
Jul 10, 2015 06:21 PM
Avenged
Jul 9, 2015 07:55 AM
skoti89
Jul 8, 2015 12:05 AM
