Wheel well engine shield
For lack of a better description . . .
that's what's gone missing from my 4Runner. I was washing it last weekend when I noticed it's gone. No idea when or why it came off. Without it
all this stuff is exposed. Should I be concerned? Had I better find one to replace it?
You can get one at a junkyard, or get some rubber sheeting at the local hardware store and make one or you can buy a set for all 4 wheels from Lift Lips (http://www.liftlips.com/).
It sure makes it easier to change the filte ron my 22re with it gone. I stay away from mud anyway. Better cooling? who knows.
You should get some clear rubber/plastic like the stuff that hangs between the bucther and the rest of the grocery store. That way you could put colored LED's behind it. hahaha
On mine, I replaced the plastic push pins with riv-nuts crimped into the holes. Then I used brass screws in the threaded inserts. Makes for easy removal and they stay on very well.
It's called a "mud skirt"... if you need the passenger and have a driver just put it on "inside out" it should fit pretty close... any piece of thick rubber would do the same thing though (you'd just have to cut it to size...
you can make your own, home depot sells this rubber carpet runner or carpet protector, not sure what they call it, but its only like $2 a foot, and cut it as long as you need it, thats what i used for the gap, works great.
found what i was looking for:
https://www.yotatech.com/forums/show...t=bodylift+gap
Jun 1, 2021 01:51 PM
skoti89
Jul 6, 2015 07:45 PM
