whats behind a 22re cylinder head?
Old Oct 1, 2009 | 02:14 PM
partypeepers's Avatar
Hi i wanna know what runs behind the cover plate behind the head i think its held down by 6 bolts? Its cause i have a leak drips from the top of the bellhousing and to the bottom of the transmission I just replaced my valve cover gasket and those half moon seals that go in the head. so i wanna knnow if oil runs through that cover plate or what? thanks
Old Oct 1, 2009 | 02:17 PM
4Crawler's Avatar
That is the EGR cooler, it cools the exhaust gas before it gets to the EGR valve and intake. As such, it has exhaust gas and coolant flowing through it.
Kiroshu's Avatar
It is a cover plate for servicing... and deals with egr.... so it is possible for it to leak but i've never see many leak before.
Old Oct 1, 2009 | 02:24 PM
im leaking like oil.. little drips of it though. any suggestions where it might be coming from. drips from driver side of bellhousing.
Old Oct 1, 2009 | 02:37 PM
Kiroshu's Avatar
Sure its coming from the top of tranny? Have you taken a flashlight while the engines running and looked back there? I've never seen a 22r leak from that back plate....like never..... sure its not ur valve cover? Might be a rear main going out.... check ur oil pan....
Old Oct 1, 2009 | 02:49 PM
checked my oil pan already no leaks dry as a desert. it might be my valve cover gasket maybe not sure. and you said that it might be the top of the bellhousing?
Old Oct 1, 2009 | 03:09 PM
Plumbrbob's Avatar
its that half moon seal directly above that EGR plate they like to leak throw a small bead of rtv on the rubber seal in the half moon area shoudl be good to go
Old Oct 1, 2009 | 03:13 PM
Kiroshu's Avatar
Yea i'd say start small replaced valve cover gasket and have circle seals at the front and rear of head. RTV them like toyota requires which is ALL OVER.... usually.... but um yea.
cars-guy
Aug 16, 2020 06:59 AM
Colington
Mar 8, 2020 09:51 AM
jasonty
41
Dec 23, 2018 01:00 PM
Sep 4, 2015 09:27 AM
ryerye13
Jul 14, 2015 08:27 AM
