What would cause pulling and a "hopping" feel?
Old Jan 25, 2014 | 11:31 AM
90YotaPU's Avatar
Randomly my truck starts pulling to the drivers side and starts hopping a little, almost like the tire is really bad out of balance. Yet if I stop or slow down and then speed up, it doesn't do it again. Happens whether going 25 mph or 65 mph. CV axles aren't torn, but I'm wondering if maybe the cold is causing them to bind up. They are at a bit of an angle from the lift. Any thoughts?
Old Jan 25, 2014 | 11:58 AM
90YotaPU's Avatar
Actually, I had a brain fart. Can't be the CVs as I have manual hubs. Must be a brake caliper hanging up.
Old Jan 27, 2014 | 07:34 AM
highonpottery's Avatar
Or bearings, neither of which you want yo seize up while driving. Bearings should be serviced like every 30k or something like that - have yours?
Old Jan 27, 2014 | 08:01 AM
CJM's Avatar
CJM
Check the frontend over. Tie rods, pitman and idler arms, steering box, bearings, shocks, ball joints.
Old Jan 27, 2014 | 08:46 AM
dropzone's Avatar
Fossilized
Not in 4WD?
Probably a bearing like CJM mentioned
Old Jan 27, 2014 | 10:59 AM
wii_tarded's Avatar
Check your tire as well, had an F-SuperDuty do this several years ago, and turned out to be a broken steel belt in the front tire.
Old Jan 27, 2014 | 11:43 AM
Gamefreakgc's Avatar
If it were a brake caliper still applying pressure you would smell the burning brakes after going 65 MPH if you then examined the vehicle.
I agree with CJM, an extensive visual inspection might reveal a torn boot or something else that's out of place. Grease splatter is also a sign of an issue.
Did you ever have the recall done on your vehicle regarding the steering? I think it was back in 2005...
cars-guy
Aug 16, 2020 06:59 AM
Eggslinger
Jun 8, 2019 03:32 PM
dumpster84
Apr 30, 2016 06:03 AM
smiley52
Jul 11, 2015 05:16 AM
Jnkml
Jul 6, 2015 01:20 PM
