What is this wire for?
Old Mar 4, 2015 | 12:20 PM
aportis72's Avatar
hello all.
This is my first real post. I have been browsing for some time and found most of my answers with the search function.
First the picture.
What is this wire I'm holding for?
I found it when I was looking for the knock sensor. It was just hanging there just above the starter left of the oil filter. Same area as the knock sensor. The wire goes up into a harness, but I can't tell what it's for. Truck runs fine other than check engine light 52 because there is no knock sensor plugged in. I'm fixing this issue.
Back ground. Truck is a 1988 SR5 4x4 extra cab 5 speed manual 22re. The guy before me put a new motor in well different haha. The stock one was shot he said so he rebuilt his brothers 1985 22RE from a 2wd. Yes I know this does not have a knock sensor, but I will tap the threads in the hole for the sensor I have on the way.
Thank you
Old Mar 4, 2015 | 12:22 PM
Terrys87's Avatar
That is the ground wire for your injectors. It gets mounted behind the rear nut on your intake manifold.
Old Mar 4, 2015 | 12:43 PM
aportis72's Avatar
Well that was easy. Haha thank you.
Old Mar 4, 2015 | 01:40 PM
aportis72's Avatar
So right here?
Old Mar 4, 2015 | 02:03 PM
aportis72's Avatar
It's to short for the location I posted could somone show where the bolt it goes to is?
Old Mar 4, 2015 | 02:27 PM
wyoming9's Avatar
Red face
Any bolt or nut on the manifold will work.
Since your truck runs I can only guess it is extra because without that wire grounded it will not run.
Old Mar 4, 2015 | 02:53 PM
aportis72's Avatar
Sounds good I put it behind the one it reached. But like you said must be extra.
Thank you
Old Mar 4, 2015 | 07:27 PM
RustBucket's Avatar
Pretty sure it shares the bolt that goes through the black support beam into the plenum.
80Truck
Oct 12, 2025 07:25 PM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
ToyoToler
Aug 8, 2015 08:43 AM
Daneums
Jul 28, 2015 11:57 AM
TDonkey
Jul 26, 2015 10:14 AM
